Rpi4 no audio from addons
I have the problem that there is no audio from add-ons.
Gui sounds, as well as audio from files are ok.
The audio coming from add-ons where working before.
To rule out any config problems, I installed OSMC on a fresh SD-Card, but the problem persists.
I also connected the rpi directly to a monitor to rule out TV / Audio receiver problems.
I just figured out the grab-logs feature, very nice!
Find the logs https://paste.osmc.tv/padugileqo
Hoping for some advice how to continue troubleshooting
Daniel
Try setting GUI resolution to 1080/60
Thx @ActionA
I tried 1080 i and p on 60Hz and both did not fix it.
Turn off passthrough in Kodi’s audio settings.
Turning off passthrough did not change the behavior
If you use stock config.txt and config-user.txt (I can see you have made modifications), does audio come back?
@sam_nazarko
I commented every out of the /boo/config-user.txt
but it didn’t fix the problem
…I had a look into dmesg and finally found a related error message
bcm2835-codec bcm2835-codec: Failed setting ctrl 00990a67, ret 3
If this is a fresh install, then I wonder if there may be a hardware issue.
fyi
I also tried my sdcard as well as the fresh installed sdcard with a friends of mine rpi4, all had the same error.
Then I rpi-updated and crushed my bootloader.
After fixing it, I’ve tested LibreELEC and the addons are working there.
Not sure was the real problem was, but I have a working kodi again.
Thank’s for your help.
cheers
Daniel
Sounds like SPI firmware may have been outdated on your device.
Should work as expected under OSMC now.
