Hi, I followed the instructions here in order to install squeezelite onto my vero 4k+. After the update to Kodi 19, my logitech media server doesn’t see my vero 4k+ as an endpoint anymore. I’ve reformatted my vero 4k+, installed the latest version, and followed that same guide again. It showed up briefly but is no longer showing up again.
I’ve looked for an up an updated guide or steps but I haven’t anything newer than that 2017 post.
I use PCM out
I don’t install any additional add ons
It’s pretty much just stock vero 4k+
Not sure if this related but the actual logitech media server will not run anymore on kernel 4.9 …i am going to have to roll back one of my Vero’s to the old image so i can get it back working …
thanks for the response. I’m not running logitech media server on my vero 4k+. It’s running on a seperate PC. If it matters, I have two vero 4k+ end points. I gave them both unique names in the setup. I’m not sure if they could be interfering with one another or not?
It is not a very descript error , when it loads we are getting an illegal instruction error .
We have been in touch with developer and he believes it should work and the version of pearl 5.28 buster ships with is compatible. I have done many things to debug , even recompiled on the Vero and tried a docker version …one of those ones where i think i have to admit defeat and go backwards if i need to use the product.
If you post these messages I can investigate.
We released Buster on 3.14 – so it won’t be a Buster issue but rather a change with the new 4.9 series kernel.
Your locale was detected as C, you may have problems with non-Latin filenames. Consider changing your LANG variable to the correct locale, i.e. en_US.utf8
dirsFor: Didn’t find a match request: [scprefs]
[21-08-31 21:19:43.6141] main::init (390) Starting Logitech Media Server (v8.2.1, 1628483320, Mon Aug 9 06:45:15 CEST 2021) perl 5.028001 - arm-linux-gnueabihf-thread-multi-64int
dirsFor: Didn’t find a match request: [videos]
dirsFor: Didn’t find a match request: [pictures]
[21-08-31 21:19:43.6449] main::init (420) OS Specific init…
[21-08-31 21:19:43.6461] main::init (467) Server settings effective user and group if requested…
[21-08-31 21:19:43.6471] main::changeEffectiveUserAndGroup (1018) Warning: Logitech Media Server must not be run as root! Trying user squeezeboxserver instead.
[21-08-31 21:19:43.6493] main::changeEffectiveUserAndGroup (1089) Running as uid: 110 / gid: 65534 65534
[21-08-31 21:19:43.6591] main::init (484) Server binary search path init…
[21-08-31 21:19:43.6606] main::init (488) Server PluginManager init…
[21-08-31 21:19:43.8957] main::init (491) Server strings init…
[21-08-31 21:19:43.8995] Slim::Utils::Strings::loadStrings (125) Retrieving string data from string cache: /var/lib/squeezeboxserver/cache/stringcache.armv7l-linux.bin
Loaded module: [DBD::SQLite] ok!
[21-08-31 21:19:43.9112] main::init (503) Server SQL init (Slim::Utils::SQLiteHelper)…
[21-08-31 21:19:43.9125] main::init (507) Async DNS init…
[21-08-31 21:19:43.9136] main::init (510) Async HTTP init…
[21-08-31 21:19:43.9148] main::init (515) SqueezeNetwork Init…
[21-08-31 21:19:43.9345] main::init (520) Download repositories init…
[21-08-31 21:19:44.0841] main::init (523) Firmware init…
[21-08-31 21:19:44.0856] main::init (526) Server Info init…
[21-08-31 21:19:44.3352] main::init (529) Server IR init…
[21-08-31 21:19:44.3582] main::init (532) Server Request init…
[21-08-31 21:19:44.3723] main::init (535) Server Queries init…
[21-08-31 21:19:44.3738] main::init (538) Server Buttons init…
[21-08-31 21:19:44.3795] main::init (546) UDP init…
[21-08-31 21:19:44.3823] main::init (549) Slimproto Init…
[21-08-31 21:19:44.3840] main::init (552) Cache init…
Illegal instruction
Add the following line: deb http://apt.osmc.tv buster-devel main
We might need to use GDB to determine what the illegal instruction is
Will the kodi log catch terminal commands that I execute through putty? I started the vero4k and then I putty into it and reran the commands to start squeezelite. It’s still not working. I have a log but I don’t know what I’m looking for in it.
I guess this could have been a straight forward thing to try originally. I don’t know why this worked. I appreciate everyone’s feedback. Love the systems and product.
