Today I installed the october update on my Pi 1 and after the reboot kodi got stuck in a sad face loop.
If i manually install the previous rbp1-mediacenter-osmc_16.1.0-20_armhf.deb everything works fine.
If I install the rbp1-mediacenter-osmc_16.1.0-24_armhf.deb kodi get stuck in the sad face loop again.
In System Journal I found this suspicious line:
Nov 04 22:09:05 pi mediacenter[2543]: *** Error in `/usr/lib/kodi/kodi.bin’: free(): invalid pointer: 0xa43453b8 ***
You can find the full log here:
System Journal
Can anyone help to fix this?
Thx
To get a better understanding of the problem you are experiencing we need more information, including full debug logs from you. Our wiki contains detailed steps for providing the relevant info we need to help you.
Also, please try the following commands as the default osmc
user:
mv /home/osmc/.kodi /home/osmc/kodi.bak
Ok thanks yknivag.
I moved .kodi and actual kodi mediacenter started flawlessly.
Afterwards I restored the .kodi backup and removed a suspicious pvr addon which causes the trouble. All fine now.
Thank you for the nice hint!
Glad you got up and running.
