I updated my pretty new Vero 4K today with the latest update by following a reminder when I was going to use it. Sadly, after the update, the vero 4k is stuck in a reboot loop. It shows the menu for 2 seconds and then switches to the sad smiley and is stuck there for about 10 seconds, and this loop continues on and on…
I have the same problem, it started today after the update. I tried to run the commands from @ActionA and @dillthedog, but they didn’t resolve problem.
Also I checked my home folder and the .flexget folder that I had there now is gone, it may have something to do with the problem?
I can’t run this either, there’s nothing inside /usr/share/kodi/addons/script.module.osmcsetting.logging/…
And now things just got a lot worse, I’ve checked my two hard disk (3TB each one) and they are completly blank… I just lost my movies, tv shows, music, everything…
@dfabarbosa I’m sorry to hear you’re having a problem with your Vero 4K.
I’d recommend a reinstallation.
If you still experience problems, we’ll send you a priority replacement promptly. Filesystem corruption shouldn’t be happening on the Vero 4K unless you’ve experienced power loss, because we use very robust eMMC storage which is certifiable for industrial applications.
Please let me know your order # so we can proceed further.
