Sad face on me and my vero
Hi all
seems my vero had a rough night last night and is very unhappy this morning.
updated to RC2 yesterday no problems and was using for a few hours after the upgrade but came down this morning to a sad face in a square with blue background then screen turns black then flicks back the sad face again .
dmesg shows:
[  284.096471] Console: switching to colour frame buffer device 240x67
[  295.198039] Console: switching to colour dummy device 80x30
[  295.540942] Console: switching to colour frame buffer device 240x67
[  302.031121] EXT4-fs (mmcblk0p2): error count since last fsck: 178
[  302.031143] EXT4-fs (mmcblk0p2): initial error at time 1428446514: ext4_mb_generate_buddy:757
[  302.031155] EXT4-fs (mmcblk0p2): last error at time 1428572257: ext4_mb_generate_buddy:756
[  306.627340] Console: switching to colour dummy device 80x30
[  306.971315] Console: switching to colour frame buffer device 240x67
[  318.076550] Console: switching to colour dummy device 80x30
[  318.421796] Console: switching to colour frame buffer device 240x67
[  329.522650] Console: switching to colour dummy device 80x30
[  329.864320] Console: switching to colour frame buffer device 240x67
[  340.969353] Console: switching to colour dummy device 80x30
[  341.310478] Console: switching to colour frame buffer device 240x67
[  352.415356] Console: switching to colour dummy device 80x30
[  352.759729] Console: switching to colour frame buffer device 240x67
[  363.875209] Console: switching to colour dummy device 80x30
[  364.218206] Console: switching to colour frame buffer device 240x67
[  375.307220] Console: switching to colour dummy device 80x30
[  375.653383] Console: switching to colour frame buffer device 240x67
nothing much in kodi log that I can see, nothing since around 7 this morning (before I was awake)
23:13:51 T:1395561504  NOTICE: Previous line repeats 1 times.
23:13:51 T:1395561504  NOTICE: Thread JobWorker start, auto delete: true
06:59:07 T:1395561504  NOTICE: Previous line repeats 23 times.
06:59:07 T:1395561504  NOTICE: Thread BackgroundLoader start, auto delete: false
06:59:07 T:1542452256  NOTICE: Thread JobWorker start, auto delete: true
any suggestions :cry:
thanks
Pete
Upload the entire log to http://paste.osmc.io/ and provide the guys with a the link.
kodi.log - http://paste.osmc.io/egolenopev.coffee
dmesg - http://paste.osmc.io/qiravakuci.vhdl
pete
p.s no idea how I managed to post in general discussion i was in help and support when I created it :smile:
You can always edit it after you posted. Just did it for you :slight_smile:
thanks :smile:
Pastebin your guisettings.xml please and also put kodi into debugging (then reboot and post the kodi.log again) mode via advancedsettings.xml (see kodi wiki) I suspect it tries to switch to non existing Modeline.
http://paste.osmc.io/worejetuco.xml - guisettings.xml
now apologies if im doing something stupid but trying to create the advancedsettings file in ~/.kodi/userdata I get the following: (tried with sudo and get the same output)
‘advancedsettings.xml’ Read-only file system
Pete
ok thats strange, I loaded the SD on my laptop and created the advanced setting file which worked booted the vero back up and its booted fine this time :confused:
Pete
That means your sdcard’s journal was broken before:
[ 1.520048] EXT4-fs (mmcblk0p2): recovery complete
[ 1.520065] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.520107] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
Yeah, one can also see that in:
[ 302.031141] EXT4-fs (mmcblk0p2): error count since last fsck: 178
[ 302.031161] EXT4-fs (mmcblk0p2): initial error at time 1428446514: ext4_mb_generate_buddy:757
[ 302.031173] EXT4-fs (mmcblk0p2): last error at time 1428572257: ext4_mb_generate_buddy:756
Did you have a power outage? Removed the plug without shutting down?
not that im aware of no, but I have seen the second 3 lines started coming up recently (didnt know if they were serious or not) but believe they started since I restored a dd image of the card :s is it likely to go again ? just check dmesg again and that error count message is still there, is there any error checking or anything I should do on the card if the filesystem is a bit messed up ? I have a ubuntu laptop available that can read the card if required
Pete
Yeah, fsck the partitions from your ubuntu pc - make sure they are umounted.
These commands may help you:
  • Insert into laptop
  • Run ```
    sudo fsck.ext4 /dev/sdb
(verify that /dev/sdb is your device).
seems happy now no more warnings, thanks
