Sometimes my Raspberry Pi gets frozen and needs a hard reset.
Transmission settings get reset, ratio is off and worst of all the blocklist is off.
Is it possible to have these settings saved more thoroughly?
It’s a quirk of transmission. You make a change and it gets lost because transmission-daemon only saves its in-memory settings when it shuts down. The only way I know to avoid this is to make the changes, then quit and restart transmission.
Thanks, I’ll try that soon.
You’ll have to stop transmission, change the settings then start transmission, that’ll fix it.
