Hi;
I’ve enjoyed OSMC for a while now, and must say you guys are doing excellent work.
Recently i had the SD-card on mye Pi3 start acting up on me, so i have had a lot of reinstall lately. And following this, alot of fresh scanning of media sources. Some of the folders/tvshows i have on my media source has names that does not immediately get a hit from thetvdb, but i have usually got around this with a manual “Scan to Library”.
This functionallity does not seem to be working any more.
I turned on debug logging and this is the relevant output when bring up the Options-meny, and go up once to get to the bottom and then select “Scan to Lilbrary” :
11:00:35.753 T:1958993920 DEBUG: ------ Window Init (DialogContextMenu.xml) ------
11:00:35.780 T:1806373872 DEBUG: PushCecKeypress - received key e5 duration 103 (rep:0 size:0)
11:00:35.781 T:1806373872 DEBUG: PushCecKeypress - ignored key e5
11:00:41.371 T:1763701744 DEBUG: script.module.osmcsetting.updates : - blurp 9 - DialogContextMenu.xml
11:00:47.442 T:1806373872 DEBUG: PushCecKeypress - received key a6 duration 0 (rep:0 size:0)
11:00:47.442 T:1806373872 DEBUG: PushCecKeypress - added key a6
11:00:47.451 T:1958993920 DEBUG: OnKey: 166 (0xa6, obc89) pressed, action is Up
11:00:47.675 T:1806373872 DEBUG: PushCecKeypress - received key a6 duration 233 (rep:0 size:0)
11:00:47.675 T:1806373872 DEBUG: PushCecKeypress - ignored key a6
11:00:58.856 T:1806373872 DEBUG: PushCecKeypress - received key b duration 0 (rep:0 size:0)
11:00:58.856 T:1806373872 DEBUG: PushCecKeypress - added key b
11:00:58.887 T:1958993920 DEBUG: OnKey: 11 (0x0b, obc244) pressed, action is Select
11:00:59.090 T:1806373872 DEBUG: PushCecKeypress - received key b duration 235 (rep:0 size:0)
11:00:59.091 T:1806373872 DEBUG: PushCecKeypress - ignored key b
In contrast, this is the output when selecting “Scan for new media” from the same media (options, up, up, select, i have masked the shows name and paths to media sources)
11:01:08.947 T:1958993920 DEBUG: ------ Window Init (DialogContextMenu.xml) ------
11:01:09.001 T:1806373872 DEBUG: PushCecKeypress - received key e5 duration 94 (rep:0 size:0)
11:01:09.001 T:1806373872 DEBUG: PushCecKeypress - ignored key e5
11:01:10.049 T:1806373872 DEBUG: PushCecKeypress - received key a6 duration 0 (rep:0 size:0)
11:01:10.049 T:1806373872 DEBUG: PushCecKeypress - added key a6
11:01:10.084 T:1958993920 DEBUG: OnKey: 166 (0xa6, obc89) pressed, action is Up
11:01:10.240 T:1806373872 DEBUG: PushCecKeypress - received key a6 duration 191 (rep:0 size:0)
11:01:10.240 T:1806373872 DEBUG: PushCecKeypress - ignored key a6
11:01:12.397 T:1806373872 DEBUG: PushCecKeypress - received key a6 duration 0 (rep:0 size:0)
11:01:12.398 T:1806373872 DEBUG: PushCecKeypress - added key a6
11:01:12.442 T:1958993920 DEBUG: OnKey: 166 (0xa6, obc89) pressed, action is Up
11:01:12.590 T:1806373872 DEBUG: PushCecKeypress - received key a6 duration 193 (rep:0 size:0)
11:01:12.591 T:1806373872 DEBUG: PushCecKeypress - ignored key a6
11:01:15.579 T:1806373872 DEBUG: PushCecKeypress - received key b duration 0 (rep:0 size:0)
11:01:15.699 T:1806373872 DEBUG: PushCecKeypress - added key b
11:01:15.711 T:1958993920 DEBUG: OnKey: 11 (0x0b, obc244) pressed, action is Select
11:01:15.770 T:1806373872 DEBUG: PushCecKeypress - received key b duration 192 (rep:0 size:0)
11:01:15.771 T:1806373872 DEBUG: PushCecKeypress - ignored key b
11:01:15.983 T:1958993920 DEBUG: ------ Window Deinit (DialogContextMenu.xml) ------
11:01:16.004 T:1574257648 DEBUG: Thread JobWorker start, auto delete: true
11:01:16.064 T:1958993920 DEBUG: ------ Window Init (DialogExtendedProgressBar.xml) ------
11:01:16.093 T:1574257648 NOTICE: VideoInfoScanner: Starting scan …
11:01:16.093 T:1958986736 DEBUG: CAnnouncementManager - Announcement: OnScanStarted from xbmc
11:01:16.093 T:1958986736 DEBUG: GOT ANNOUNCEMENT, type: 16, from xbmc, message OnScanStarted
11:01:16.165 T:1574257648 DEBUG: VideoInfoScanner: No NFO file found. Using title search for ‘smb://PATH_TO_SHOW/’
11:01:16.169 T:1574257648 DEBUG: FindMovie: Searching for ‘TV_SHOW’ using The TVDB scraper (path: ‘/home/osmc/.kodi/addons/metadata.tvdb.com’, content: ‘tvshows’, version: ‘1.8.5’)
11:01:16.200 T:1574257648 DEBUG: scraper: CreateSearchUrl returned http://thetvdb.com/api/GetSeries.php?seriesname=TV_SHOW&language=en
11:01:16.203 T:1574257648 DEBUG: scraper: GetSearchResults returned <?xml version="1.0" encoding="utf-8" standalone="yes"?>
11:01:16.206 T:1574257648 DEBUG: FindMovie: Searching for ‘TV_SHOW’ using The TVDB scraper (path: ‘/home/osmc/.kodi/addons/metadata.tvdb.com’, content: ‘tvshows’, version: ‘1.8.5’)
11:01:16.207 T:1574257648 DEBUG: scraper: CreateSearchUrl returned http://thetvdb.com/api/GetSeries.php?seriesname=TV_SHOW&language=en
11:01:16.210 T:1574257648 DEBUG: scraper: GetSearchResults returned <?xml version="1.0" encoding="utf-8" standalone="yes"?>
11:01:16.210 T:1574257648 WARNING: No information found for item ‘smb://PATH_TO_SHOW/’, it won’t be added to the library.
11:01:16.214 T:1574257648 DEBUG: VideoInfoScanner: No (new) information was found in dir smb://PATH_TO_SHOW
11:01:17.323 T:1574257648 NOTICE: VideoInfoScanner: Finished scan. Scanning for video info took 00:01
Not sure if this is a OSMC issue, a kodi issue or if im doing somethine wrong
But it looks like the meny-item simply doesnt do anything. As a work around, i looks like a nfo file should get the trick done. But it is annoying none the less.
Anyone else see this problem?
EDIT: Im using the latest 07-2017 build of OSMC. I dont think i saw this problem i 06.
