hi people, got an issue with using callbacks, scheduler or similar addon on osmc.
I created an addon gathering external ip and make a little popup. works fine so far.
What i now want to do is to run after x mins. So either i rewrite it as a service addon or use cron/callbacks/scheduler to run it every x minutes.
So as im lazy and not want to recreate for now as a service addon, i wanted to test callbacks. I install from Kodi repo and it works till the point i choose an event like “player started” and click the test button an error pops up related events issues on line 182.
Checked google and stuff and could not find anything related so i thought this might be related to osmc as other seem to have no issue with this.
i use builtin-script option “RunScript(script.extip)”
(tested before via “xbmc executebuiltin RunScript(script.extip)”) and it works fine.
Any idea or possible solutions?
(to mention the other options: scheduler does not allow define minutes, xbmccron does not work at all maybe its too old)
I would be happy if anyone could check if callbacks is working in general on osmc, would be great. Else i will rewrite the addon as a service addon.
Best regards,
r0tt
