Tried to watch Dune (2021) 4K this week on a Vero 4K and at the start of the film areas of the screen turn green or have green streaks. I thought at first it was an issue with my encoding from the original disc, but I tried Bad Boys 4K tonight and that is doing it too now as you can see from the attached photo.
reproduce the issue
upload the log set (all configs and logs!) either using the
Log Uploader
method within the My OSMC menu in the GUI or thessh
method invoking commandgrab-logs -A
http://paste.osmc.tv/qirucirowi
I have tried playing the same 4K films using a Roku stick connected through the same amp and that has no issues with the colour.
Your log doesn’t show an attempt to play a file.
I played a film for about 30 seconds.
Please post mediainfo for the two films you have issues with.
- is it only at the beginning you see these green streaks?
- any other 4k films showing this?
Format : Matroska
Format version : Version 4
File size : 8.78 GiB
Duration : 1 h 58 min
Overall bit rate : 10.6 Mb/s
Movie name : Bad Boys (1995)
Encoded date : UTC 2020-05-07 15:06:57
Writing application : mkvmerge v46.0.0 (‘No Deeper Escape’) 64-bit
Writing library : libebml v1.3.10 + libmatroska v1.5.2 / Lavf58.39.101
Video
ID in the original source medium : 4113 (0x1011)
Format : HEVC
Format profile : Main 10@L5.1@High
HDR format : SMPTE ST 2086, HDR10 compatible
Codec ID : V_MPEGH/ISO/HEVC
Bit rate : 6 748 kb/s
Width : 3 840 pixels
Height : 2 076 pixels
Display aspect ratio : 1.85:1
Frame rate mode : Constant
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.035
Stream size : 5.60 GiB (64%)
Writing library : x265 3.1.1+1-04b37fdfd2dc:[Linux][GCC 9.2.0][64 bit] 10bit
Encoding settings : cpuid=1111039 / frame-threads=4 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-
res=3840x2076 / interlace=0 / total-frames=0 / level-idc=51 / high-tier=1 / uhd-bd=0 / ref=3 / no-allow-non-conformance / repeat-headers / annexb / no-aud /
no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=23 / keyint=250 / gop-lookahead=0 / bframes=4 / b-adapt=0 / b-pyramid / bframe-bias=0 / r
c-lookahead=15 / lookahead-slices=8 / scenecut=40 / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / no-rect / no-amp / max-tu-size=32 / tu-i
nter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=0 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-i
ntra / strong-intra-smoothing / max-merge=2 / limit-refs=3 / no-limit-modes / me=1 / subme=2 / merange=57 / temporal-mvp / weightp / no-weightb / no-analyze-
src-pics / deblock=0:0 / sao / no-sao-non-deblock / rd=2 / no-early-skip / rskip / fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip
/ rdpenalty=0 / psy-rd=2.00 / psy-rdoq=0.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=crf / crf=26.0 / qcomp=0.60 / qpstep=4 / stats-write
=0 / stats-read=0 / vbv-maxrate=160000 / vbv-bufsize=160000 / vbv-init=0.9 / crf-max=0.0 / crf-min=0.0 / ipratio=1.40 / pbratio=1.30 / aq-mode=1 / aq-strengt
h=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0
/ colorprim=9 / transfer=16 / colormatrix=9 / chromaloc=0 / display-window=0 / master-display=G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(400000
00,50)cll=6239,4864 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pp
s / no-multi-pass-opt-rps / scenecut-bias=0.05 / no-opt-cu-delta-qp / no-aq-motion / hdr / no-hdr-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-
level=5 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=0 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-anal
ysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00
Language : English
Default : No
Forced : No
Color range : Limited
Color primaries : BT.2020
Transfer characteristics : PQ
Matrix coefficients : BT.2020 non-constant
Mastering display color primaries : Display P3
Mastering display luminance : min: 0.0050 cd/m2, max: 4000 cd/m2
Maximum Content Light Level : 6239 cd/m2
Maximum Frame-Average Light Level : 4864 cd/m2
Original source medium : Blu-ray
Audio
ID in the original source medium : 4352 (0x1100)
Format : MLP FBA 16-ch
Format/Info : Meridian Lossless Packing FBA with 16-channel presentation
Commercial name : Dolby TrueHD with Dolby Atmos
Codec ID : A_TRUEHD
Bit rate mode : Variable
Bit rate : 3 750 kb/s
Maximum bit rate : 5 721 kb/s
Channel(s) : 8 channels
Channel layout : L R C LFE Ls Rs Lb Rb
Sampling rate : 48.0 kHz
Frame rate : 1 200.000 FPS (40 SPF)
Compression mode : Lossless
Stream size : 3.11 GiB (35%)
Title : Surround 7.1
Language : English
Default : Yes
Forced : No
Number of dynamic objects : 11
Bed channel count : 1 channel
Bed channel configuration : LFE
Text
ID in the original source medium : 4771 (0x12A3)
Format : PGS
Muxing mode : zlib
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Duration : 1 h 54 min
Bit rate : 38.7 kb/s
Frame rate : 0.485 FPS
Count of elements : 3318
Stream size : 31.6 MiB (0%)
Language : English
Default : No
Forced : No
Format : Matroska
File size : 8.59 GiB
Duration : 1 h 47 min
Overall bit rate : 11.4 Mb/s
Movie name : Raya and the Last Dragon
Encoded date : UTC 2021-05-29 15:13:49
Writing application : mkvmerge v57.0.0 (‘Till The End’) 64-bit
Writing library : libebml v1.4.2 + libmatroska v1.6.4
Video
Format : HEVC
Format profile : Main 10@L5@Main
Bit rate : 2 244 kb/s
Height : 1 608 pixels
Display aspect ratio : 2.40:1
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.015
Stream size : 1.68 GiB (20%)
Writing library : x265 3.5+1-f0c1022b6:[Linux][GCC 10.2.0][64 bit] 10bit
res=3840x1608 / interlace=0 / total-frames=0 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=3 / no-allow-non-conformance / repeat-headers / annexb / no-aud / n
o-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=23 / keyint=250 / gop-lookahead=0 / bframes=4 / b-adapt=0 / b-pyramid / bframe-bias=0 / rc
-lookahead=15 / lookahead-slices=8 / scenecut=40 / hist-scenecut=0 / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / no-rect / no-amp / max-
tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=0 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 /
no-constrained-intra / strong-intra-smoothing / max-merge=2 / limit-refs=3 / no-limit-modes / me=1 / subme=2 / merange=57 / temporal-mvp / no-frame-dup / no
-hme / weightp / no-weightb / no-analyze-src-pics / deblock=0:0 / sao / no-sao-non-deblock / rd=2 / selective-sao=4 / no-early-skip / rskip / fast-intra / no
-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=0.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=
0 / rc=crf / crf=24.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / ipratio=1.40 / pbratio=1.30 / aq-mode=2 / aq-strength=1.00 / cutree / zone-cou
nt=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=9 / transfer=1
6 / colormatrix=9 / chromaloc=0 / display-window=0 / master-display=G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(10000000,50) / cll=0,0 / min-lum
a=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / s
cenecut-bias=0.05 / hist-threshold=0.03 / no-opt-cu-delta-qp / no-aq-motion / hdr10 / no-hdr10-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-lev
el=0 / analysis-save-reuse-level=0 / analysis-load-reuse-level=0 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 /
no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq /
no-svt / no-field / qp-adaptation-range=1.00 / scenecut-aware-qp=0conformance-window-offsets / right=0 / bottom=0 / decoder-max-rate=0 / no-vbv-live-multi-pa
ss
Default : Yes
Forced : No
Mastering display luminance : min: 0.0050 cd/m2, max: 1000 cd/m2
Audio #1
Codec ID : A_TRUEHD
Bit rate : 8 470 kb/s
Maximum bit rate : 11.2 Mb/s
Bit depth : 24 bits
Stream size : 6.36 GiB (74%)
Language : English
Default : Yes
Forced : No
Number of dynamic objects : 13
Audio #2
Format : AC-3
Format/Info : Audio Coding 3
Commercial name : Dolby Digital
Codec ID : A_AC3
Bit rate mode : Constant
Bit rate : 640 kb/s
Channel(s) : 6 channels
Compression mode : Lossy
Stream size : 492 MiB (6%)
Title : Surround 5.1
Language : English
Service kind : Complete Main
Default : No
Forced : No
Text
ID in the original source medium : 4768 (0x12A0)
Format : PGS
Muxing mode : zlib
Duration : 1 h 46 min
Bit rate : 44.3 kb/s
Frame rate : 0.602 FPS
Count of elements : 3839
Stream size : 33.7 MiB (0%)
Language : English
Default : No
Forced : No
I’ve only watched the start of these films now as I had issues playing Dune (2021):
Format : Matroska
File size : 5.09 GiB
Duration : 2 h 35 min
Overall bit rate : 4 692 kb/s
Movie name : Dune
Encoded date : UTC 2022-05-27 20:27:42
Writing application : mkvmerge v68.0.0 (‘The Curtain’) 64-bit
Video
Format : HEVC
Bit rate : 925 kb/s
Height : 1 604 pixels
Color space : YUV
Bit depth : 10 bits
Bits/(Pixel*Frame) : 0.006
Stream size : 1.00 GiB (20%)
Writing library : x265 3.5+1-f0c1022b6:[Linux][GCC 11.2.0][64 bit] 10bit
res=3840x1604 / interlace=0 / total-frames=0 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=3 / no-allow-non-conformance / repeat-headers / annexb / no-aud / n
o-eob / no-eos / no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=23 / keyint=250 / gop-lookahead=0 / bframes=4 / b-adapt=0 / b-pyramid /
bframe-bias=0 / rc-lookahead=15 / lookahead-slices=8 / scenecut=40 / no-hist-scenecut / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / no-r
ect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=0 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-int
ra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=2 / limit-refs=3 / no-limit-modes / me=1 / subme=2 / merange=57 / temporal-mvp
/ no-frame-dup / no-hme / weightp / no-weightb / no-analyze-src-pics / deblock=0:0 / sao / no-sao-non-deblock / rd=2 / selective-sao=4 / no-early-skip / rski
p / fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=0.00 / no-rd-refine / no-lossless / cbq
poffs=0 / crqpoffs=0 / rc=crf / crf=26.0 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=0 / ipratio=1.40 / pbratio=1.30 / aq-mode=2 / aq-strength=1.00
/ cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / color
prim=9 / transfer=16 / colormatrix=9 / chromaloc=0 / display-window=0 / master-display=G(13250,34500)B(7500,3000)R(34000,16000)WP(15635,16450)L(40000000,50)
/ cll=787,239 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no
-multi-pass-opt-rps / scenecut-bias=0.05 / hist-threshold=0.03 / no-opt-cu-delta-qp / no-aq-motion / hdr10 / no-hdr10-opt / no-dhdr10-opt / no-idr-recovery-s
ei / analysis-reuse-level=0 / analysis-save-reuse-level=0 / analysis-load-reuse-level=0 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / re
fine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-sin
gle-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00 / scenecut-aware-qp=0conformance-window-offsets / right=0 / bottom=0 / decoder-max-rate=0
/ no-vbv-live-multi-pass
Default : Yes
Forced : No
Maximum Content Light Level : 787 cd/m2
Maximum Frame-Average Light Level : 239 cd/m2
Audio #1
Codec ID : A_TRUEHD
Bit rate : 3 243 kb/s
Maximum bit rate : 5 472 kb/s
Bit depth : 24 bits
Stream size : 3.52 GiB (69%)
Language : English
Default : Yes
Forced : No
Audio #2
Format : AC-3
Format settings : Dolby Surround EX
Codec ID : A_AC3
Bit rate : 448 kb/s
Stream size : 498 MiB (10%)
Language : English
Default : No
Forced : No
Text
Format : PGS
Muxing mode : zlib
Duration : 2 h 26 min
Bit rate : 26.0 kb/s
Frame rate : 0.387 FPS
Count of elements : 3406
Stream size : 27.3 MiB (1%)
Language : English
Default : No
Forced : No
Which I couldn’t watch due to the green streaks.
It has been all 4K films that I’ve tried.
Thank you. When you say ‘started to turn green’ you mean it didn’t happen before? When did it start?
The last 4K film I played was on the 1st April and that played without issue. Last week was the first time I’d tried to play a 4K film since then and at first I thought it was due to how I’d encoded the film, but then when I tried older films that had worked before I realised there was an issue.
These are the updates I’ve performed since 1st April.
Start-Date: 2022-04-01 19:59:25
Commandline: /usr/bin/apt-real dist-upgrade
Requested-By: osmc (1000)
Install: vero364-image-4.9.113-64-osmc:arm64 (4.9.113-64-osmc, automatic)
Upgrade: linux-libc-dev:armhf (4.19.208-1, 4.19.232-1), armv7-bluez-osmc:armhf (5.43-6, 5.62-1), libc6-dev:armhf (2.28-110.1, 2.28-110.4), vero364-kernel-osm
c:arm64 (3.9.227, 3.9.233), libc6:armhf (2.28-110.1, 2.28-110.4), locales:armhf (2.28-110.1, 2.28-110.4), libexpat1:armhf (2.2.6-2+deb10u3, 2.2.6-2+deb10u4),
libc-l10n:armhf (2.28-110.1, 2.28-110.4), libc-bin:armhf (2.28-110.1, 2.28-110.4), vero3-mediacenter-osmc:armhf (19.3.0-10, 19.4.0-1), base-files-osmc:armhf
(3.1.0, 3.1.5), vero3-wifi-osmc:armhf (1.6.0-1, 1.7.0-1), mediacenter-skin-osmc:armhf (19.1.1-8, 19.1.2-12), libc-dev-bin:armhf (2.28-110.1, 2.28-110.4), mu
ltiarch-support:armhf (2.28-110.1, 2.28-110.4), armv7-connman-osmc:armhf (1.3.6-3, 1.4.0-1), mediacenter-addon-osmc:armhf (3.0.739, 3.0.740)
End-Date: 2022-04-01 20:01:21
Start-Date: 2022-05-01 17:59:40
Upgrade: libisccfg163:armhf (1:9.11.5.P4+dfsg-5.1+deb10u6, 1:9.11.5.P4+dfsg-5.1+deb10u7), libcups2:armhf (2.2.10-6+deb10u4, 2.2.10-6+deb10u5), linux-libc-dev
:armhf (4.19.232-1, 4.19.235-1), openssl:armhf (1.1.1d-0+deb10u7, 1.1.1n-0+deb10u1), mariadb-common:armhf (1:10.3.31-0+deb10u1, 1:10.3.34-0+deb10u1), libicu6
3:armhf (63.1-6+deb10u2, 63.1-6+deb10u3), bind9-host:armhf (1:9.11.5.P4+dfsg-5.1+deb10u6, 1:9.11.5.P4+dfsg-5.1+deb10u7), zlib1g:armhf (1:1.2.11.dfsg-1, 1:1.2
.11.dfsg-1+deb10u1), libgmp10:armhf (2:6.1.2+dfsg-4, 2:6.1.2+dfsg-4+deb10u1), libisc1100:armhf (1:9.11.5.P4+dfsg-5.1+deb10u6, 1:9.11.5.P4+dfsg-5.1+deb10u7),
libtiff5:armhf (4.1.0+git191117-2~deb10u3, 4.1.0+git191117-2~deb10u4), liblwres161:armhf (1:9.11.5.P4+dfsg-5.1+deb10u6, 1:9.11.5.P4+dfsg-5.1+deb10u7), xz-uti
ls:armhf (5.2.4-1, 5.2.4-1+deb10u1), libxml2:armhf (2.9.4+dfsg1-7+deb10u2, 2.9.4+dfsg1-7+deb10u3), libmariadb3:armhf (1:10.3.31-0+deb10u1, 1:10.3.34-0+deb10u
1), libisccc161:armhf (1:9.11.5.P4+dfsg-5.1+deb10u6, 1:9.11.5.P4+dfsg-5.1+deb10u7), libssl1.1:armhf (1.1.1d-0+deb10u7, 1.1.1n-0+deb10u1), gzip:armhf (1.9-3,
1.9-3+deb10u1), libbind9-161:armhf (1:9.11.5.P4+dfsg-5.1+deb10u6, 1:9.11.5.P4+dfsg-5.1+deb10u7), libdns1104:armhf (1:9.11.5.P4+dfsg-5.1+deb10u6, 1:9.11.5.P4+
dfsg-5.1+deb10u7), liblzma5:armhf (5.2.4-1, 5.2.4-1+deb10u1), base-files:armhf (10.3+deb10u11, 10.3+deb10u12), tzdata:armhf (2021a-0+deb10u3, 2021a-0+deb10u4
End-Date: 2022-05-01 17:59:59
Start-Date: 2022-05-28 21:23:32
Upgrade: libcups2:armhf (2.2.10-6+deb10u5, 2.2.10-6+deb10u6), libldap-2.4-2:armhf (2.4.47+dfsg-3+deb10u6, 2.4.47+dfsg-3+deb10u7), openssl:armhf (1.1.1n-0+deb
10u1, 1.1.1n-0+deb10u2), dpkg:armhf (1.19.7, 1.19.8), libldap-common:armhf (2.4.47+dfsg-3+deb10u6, 2.4.47+dfsg-3+deb10u7), libxml2:armhf (2.9.4+dfsg1-7+deb10
u3, 2.9.4+dfsg1-7+deb10u4), libssl1.1:armhf (1.1.1n-0+deb10u1, 1.1.1n-0+deb10u2), libdpkg-perl:armhf (1.19.7, 1.19.8), dpkg-dev:armhf (1.19.7, 1.19.8)
Yup. Saw that.
The kernel you are on is pretty much EOL now. There’s a test thread for a newer kernel which @sam_nazarko could invite you to and it would be useful to know if that fixes things.
Meanwhile, can you post output of md5sum /lib/firmware/osmc/video/*
da048ceec3cbc8433b30b286cad86bc1 /lib/firmware/osmc/video/h264_enc.bin
c592fa18ef2e10cd42baa31bc5805126 /lib/firmware/osmc/video/video_ucode.bin
Nothing wrong there. Can you try just updating your system again?
Another thing to try: swapping HDMI cables and/or cleaning HDMI plugs and sockets with contact cleaner. Also see if taking your AVR out of the chain changes things.
And you could try using a whitelist to stop Vero outputting 4k and force it to 1080p which would mean HDMI isn’t working so hard - just as a test.
Then I’m out of ideas …
I’ve switched over to my other Vero 4K box on the same TV and the green streaks aren’t there. So this must be something to with the original box.
Same HDMI cables/AVR input/TV input? And for the record (it shouldn’t make any difference) is that Vero also the original version or a 4k +?
Plugged it back into the same HDMI cable, only difference is that I’m using WiFi instead of cable connection.
Vero 4K same as the other box.
If you can wait a bit, the next OSMC release should be out ‘real soon now’. Otherwise, I would suggest a back-up and re-imaging.
I suppose if I enabled debug logging on the box that works, I could compare the 2 logs to see if there’s anything that’s different?
