Hi, after a reboot my Pi2 has the following error on screen and won’t boot back up:
kernel panic not syncing vfs raspberry pi
I have read this is probably SD card corruption. I have a USB install, so supposedly only use the SD card to boot, before running OSMC from the USB stick. Is there an easy way to resolve this, without reinstalling the USB from scratch?
No, I only have a USB 8Gb stick which it is installed to, and a Bluetooth dongle attached.
I will try a fresh install, using a blank USB stick, then once it’s finished try putting the original USB stick back in (I’ll do an image backup of it first!).
OK well its not the SD, it’s the USB that’s the problem. Reinstalled with new USB, powered down and booted back up with original USB - same issue.
I’ve attempted to mount the USB in my BananaPi (only Linux box I have) and I can’t - keep getting messages about it being write protected.
Any ideas apart from a full reinstall?
root@bananapi /media/usb # mount /dev/sdf1 /media/usb mount: block device /dev/sdf1 is write-protected, mounting read-only
mount: wrong fs type, bad option, bad superblock on /dev/sdf1,
missing codepage or helper program, or other error
In some cases useful info is found in syslog - try
dmesg | tail or so
