While performing the most recent update there was a hiccup and my file system got hosed. My attempts to repair it met with failure. Since I was going to have to reload anyway I decided to test the SD card. It failed miserably. Every single block failed the comparison. I just popped the SD card back into my laptop and it still has the original contents, so, since the test is supposed to be destructive, either badblocks failed its task completely or the card is toast.
I bought a new card and reinstalled OSMC/KODI. Assuming the badblocks test was accurate and the old card was worn out, I started looking for ways to minimize wear on the new card. I don’t really mind spending $10 a year on a new SD card but I’d rather not go through the hassle. One suggestion I found online was to alter /etc/fstab to mount several of the /var directories as tmpfs. This didn’t work quite as planned, with all kinds of complaints about journal issues on reboot and it ending in safe mode. I took the SD card to another computer and put things back as they were. Everything went fine on the subsequent boot.
Is there some way to minimize non-essential writes to the SD card? The tmpfs trick looked promising but obviously didn’t work as intended. Is there some way to get this to work without aborting the boot?
Sorry if this is an old and worn out topic. I did a forum search and didn’t find anything that appeared to cover this specific topic.
