I was just setting up my new vero 4k+. I’ve connected a 8TB Seagate harddrive (NTFS) to it. Browsing files works perfectly, also playing them (.mkv,.avi etc) is no problem.
No I wanted to build a movie library by setting some of the movie folders from the harddrive as content as it is described by kodi. After setting up the source and clicking “yes” for the “update entries blabla”-window showing up, nothing happens. No percentage processing in the top corner, nothing.
And of course, none of my movies is showing up in the movie library.
I’ve tried everything by changing all options while setting-up content. Stil, nothing happens.
My movie-files are sorted in to folders by category. Some of the movies are again placed in folders with the name of the movie.
reboot the OSMC device
reproduce the issue
upload the log set either using the Log Uploader method within the My OSMC menu in the GUI or the ssh method invoking command grab-logs -A
Setting a source for the appropriate type of content is the first step. Ending this dialogue won’t start the scraper for this section, though. You can either have it update on every start or start it manually:
Before you do this, please make sure movies reside in a folder only for movies (best case: appropriately named subfolders for every movie). Same thing for TV shows.
I already did all these steps. None of them works.
As I said, no source is added, my libraries are empty. Nothing can be updated, not manually nor automatically.
I’m setting the content by choosing the movie folder of my harddrive. But nothing happens afterwards. Updating the non existing library doesn’t solve the problem. I tried it several times.
Since I bought my vero 4k+ used, can I do a factory reset? Maybe the previous owner messed something up? I see no option for a factory reset.
That would’ve belonged into the start post where you wrote
Yes, you should have done this right away with a used device. Who knows what the previous owner did to it, how he configured it to work with his network and his sources. A reinstall is the only reasonable thing to do. Go for it with the reinstall method ooZee linked.
