I have seen threads about this in the forum but on following the advice still get no further to fixing it.
On startup I see messages like Script Error: OSMC Settings.
I cannot try an update as it fails with a similar error. I have also tried a manual update by doing the below:
sudo apt-get update; sudo systemctl start manual-update
but that fails with
Archives directory /var/cache/apt/archives/partial is missing.
But on trying to create that folder it just fails
mkdir: cannot create directory ‘/var/cache/apt/archives’: Input/output error
If I query the folder using ls -l I get ???
osmc@osmc:/var/cache/apt$ sudo ls -l
ls: cannot access archives: Input/output error
ls: cannot access srcpkgcache.bin: Input/output error
total 42912
d??? ? ? ? ? ? archives
-rw-r–r-- 1 root root 22005979 Sep 27 17:00 pkgcache.bin
-??? ? ? ? ? ? srcpkgcache.bin
-rw-r–r-- 1 root root 22005979 Sep 27 17:00 srcpkgcache.bin.vecots
I have included a copy of my log file on pastebin OSMC Setting Error - Pastebin.com
Looking at it this comes up when the setting file is accessed.
Line 646
Error Type: <class 'socket.error'>
Sounds like it cannot connect to something? But I can ping google from the pi and can connect to it over my network fine.
Any ideas?
