Hello,
I’m trying to toggle the LED light and change the CPU governor via shell commands.
The only thing I found is this here: https://github.com/osmc/osmc/blob/27cd4affa976512a217603cefcf3ab36cc8f50fc/package/mediacenter-osmc/patches/vero3-120-add-standby-support.patch#L58 and following lines.
So I tried writing 255
to /sys/class/leds/led-sys/brightness
to turn the LED on and 0
to turn it off.
This works, but as far as I understand C++, that line is writing 0 or 1, not 255, so I wanted to make sure that it is correct and I won’t break anything.
Same thing for the governor, I could write ondemand
or powersave
to /sys/devices/system/cpu/cpuX/cpufreq/scaling_governor
(where X is 0 to 3), but I’m wondering if that would be the right way to do it or I’m missing something.
Thanks.
EDIT: nevermind, the LED actually works as expected: 1 for off, 0 for on!
