I did set the SMB backup folder in MyOSM for settings backup, but when manually starting a backup in MyOSMC it says “Location for backup not provided”
Can you try again with debug logs enabled?
Hi Sam, I tried to run a settings backup today and it worked. No changes made to the OSMC box or to the share its writing the backup to. It is a mystery.
In case it stops working again i’ll be back with more info.
