I just got my new vero brand new!
Try to acces my shared files on my PC
And it s just dont work! Iam very
wtf!?
Maybe i just dont use the best way to acces my files. Witch protocol do you use?
wtf!?
If your NAS supports you should use NFS as it is best performance (least overhead).
Also you should best mount it via FSTAB as the buildin Kodi library is not the best.
I assume you are trying to reach it via SMB? SMB Browsing (a SMB1 feature) has been disabled due to security issues (Wanna Cry) if you need to use it you can activate under Settings → Services → SMB Client
