Hello there.
I’ve had my 4K+ for a month or 2 now, and I’m really impressed. It plays anything you throw at it, and it’s so tiny.
I’ve set up my harmony hub to control it and used the key map editor plugin to be able to suspend it when I’m not using it.
My question is, is suspend the only option? Or can I power down and back up from the remote?
Only suspend, once its been shutdown; it has to be unplugged and plugged back in to restart.
Thanks Tom.
Thought so.
Remember it being the same when I had a Pi.
