I have several pi-3s working with latest OSMC 20.1
tried couple of skins and they trashed my setup. 2 different pi,s so reformatted them installed fresh OSMC first installed several skins no troubles until I started to scan in my library and now the crashing begins !!
Here is the log. hastebin
https://paste.kodi.tv/hediyafufi
I would recommend to dump your userdata then NOT install again a skin that is not compatible with the version of Kodi your running. If your going to install a very easy to break skin you should do a bit more reading up before installing it. Also, any support for skin problems should be directed towards the skin dev, not here. If you dump your userdata and with a stock skin it still crashes during library updates and you want help then you would need to provide a full log set.
Dumping a user data? It was a new formatted card no data also I thought the Skins built in to kodi are already been tested why else would they list them
Bullshit…
repository.bingie v1.0.2 installed
That repository was installed but the web link was dead and never got the skin. Google search showed it the best look alike of netflix skin. So I went a head installed the ones from Kodi.
