I’ve set my Vero V to sleep after 120 mins, which works. When I want to wake it up, using the home button on the remote control it does not wake it up.
How should I be waking it up ? my only solution is either to unplug the power and reconnect or disable sleep mode.
It would appear there you are right, sleep AND shutdown was 120mins, I assume sleep would wake up via the remote, shutdown would need a unplug/plug back in ?
That should be the case, yes. But I am really unfamiliar with Kodi timers.
A log should show us what Kodi really decides to do with those timers, if you still have issues
