Very minor bug, but always worth mentioning, I guess.
Since the update yesterday, replacing a video file with a higher quality file now doesn’t show all properties in the bottom left hand corner (audio config, codec etc.). When the replacement file loads, the info pane no longer shows the aspect ratio. So, instead of this:
H.264 Full HD (1080) 2.40:1 it reads H.264 Full HD (1080)
This did work fine in the previous version(s)
Again, nothing major. Just worth flagging!
