Hallo!
Yesterday I received a very small update for my Install of OSMC on RaspberyPi. I cant find any information on it. So what was updated yesterday?
Thanks!
Alex
Are you sure you’re on the stable updates branch? Post the output of
cat /etc/apt/sources.list
deb Index of /debian stretch main contrib non-free
deb Index of /debian stretch-updates main contrib non-free
deb http://security.debian.org/ stretch/updates main contrib non-free
deb http://apt.osmc.tv stretch main
Most likely was just debian updates. grab-logs -a will show exactly what packages it was.
Thanks ActionA!
Sounds like it:
Start-Date: 2018-05-31 17:25:41
Commandline: /usr/bin/apt-get-real -o APT::Status-Fd=4 -o APT::Keep-Fds::=5 -o APT::Keep-Fds::=6 -f -y dist-upgrade
Upgrade: libcurl3:armhf (7.52.1-5+deb9u5, 7.52.1-5+deb9u6), procps:armhf (2:3.3.12-3, 2:3.3.12-3+deb9u1), libprocps6:armhf (2:3.3.12-3, 2:3.3.12-3+deb9u1), base-files-osmc:armhf (2.5.8, 2.6.2), libmad0:armhf (0.15.1b-8, 0.15.1b-8+deb9u1), wget:armhf (1.18-5+deb9u1, 1.18-5+deb9u2), curl:armhf (7.52.1-5+deb9u5, 7.52.1-5+deb9u6), tzdata:armhf (2018d-0+deb9u1, 2018e-0+deb9u1)
End-Date: 2018-05-31 17:25:51Start-Date: 2018-05-31 17:25:55
Commandline: /usr/bin/apt-get-real -o APT::Status-Fd=4 -o APT::Keep-Fds::=5 -o APT::Keep-Fds::=6 -y purge rbp2-image-4.14.26-2-osmc
Purge: rbp2-image-4.14.26-2-osmc:armhf (2)
End-Date: 2018-05-31 17:25:58
So all is well!
Alex
You’ll only get a Debian update via My OSMC automatically if there are OSMC updates.
Hallo!
So it stays strange that I get a Update notice for these Updates…
Thanks!
Alex
I haven’t pushed any changes since early May
Hi. I also got this update. Checked the logs, and seems to be the same packages as AlexDausF got.
Same here…
I did a manual update check before 5 days and it came up an update… Same procedure , restart after update… etc…
It was a small update, and i remember that before update i had
OSMC 2018.04-1 and now after the update 2018.04-2
Same here after manual update OSMC VERSION_ID=“2018.04-2”
Log started: 2018-06-06 19:06:38
Preparing to unpack …/0-base-files-osmc_2.6.2_all.deb …
Unpacking base-files-osmc (2.6.2) over (2.5.8) …
Preparing to unpack …/1-tzdata_2018e-0+deb9u1_all.deb …
Unpacking tzdata (2018e-0+deb9u1) over (2018d-0+deb9u1) …
Preparing to unpack …/2-libprocps6_2%3a3.3.12-3+deb9u1_armhf.deb …
Unpacking libprocps6:armhf (2:3.3.12-3+deb9u1) over (2:3.3.12-3) …
Preparing to unpack …/3-procps_2%3a3.3.12-3+deb9u1_armhf.deb …
Unpacking procps (2:3.3.12-3+deb9u1) over (2:3.3.12-3) …
Preparing to unpack …/4-wget_1.18-5+deb9u2_armhf.deb …
Unpacking wget (1.18-5+deb9u2) over (1.18-5+deb9u1) …
Preparing to unpack …/5-curl_7.52.1-5+deb9u6_armhf.deb …
Unpacking curl (7.52.1-5+deb9u6) over (7.52.1-5+deb9u5) …
Preparing to unpack …/6-libcurl3_7.52.1-5+deb9u6_armhf.deb …
Unpacking libcurl3:armhf (7.52.1-5+deb9u6) over (7.52.1-5+deb9u5) …
Preparing to unpack …/7-libmad0_0.15.1b-8+deb9u1_armhf.deb …
Unpacking libmad0:armhf (0.15.1b-8+deb9u1) over (0.15.1b-8) …
Setting up libcurl3:armhf (7.52.1-5+deb9u6) …
Setting up tzdata (2018e-0+deb9u1) …
Current default time zone: ‘Europe/Amsterdam’
Local time is now: Wed Jun 6 19:06:49 CEST 2018.
Universal Time is now: Wed Jun 6 17:06:49 UTC 2018.
Run ‘dpkg-reconfigure tzdata’ if you wish to change it.
Setting up libprocps6:armhf (2:3.3.12-3+deb9u1) …
Setting up base-files-osmc (2.6.2) …
Fixing permissions on busybox.
Created symlink /etc/systemd/system/multi-user.target.wants/osmc-id-generator.service → /lib/systemd/system/osmc-id-generator.service.
Created symlink /etc/systemd/system/timers.target.wants/osmc-report-stats.timer → /lib/systemd/system/osmc-report-stats.timer.
Setting up procps (2:3.3.12-3+deb9u1) …
Processing triggers for libc-bin (2.24-11+deb9u3) …
Processing triggers for systemd (232-25+deb9u3) …
Setting up wget (1.18-5+deb9u2) …
Setting up libmad0:armhf (0.15.1b-8+deb9u1) …
Setting up curl (7.52.1-5+deb9u6) …
Log ended: 2018-06-06 19:06:51
Log started: 2018-06-06 19:06:57
Removing rbp2-image-4.14.26-2-osmc (2) …
Examining /etc/kernel/prerm.d.
Examining /etc/kernel/postrm.d .
Purging configuration files for rbp2-image-4.14.26-2-osmc (2) …
Log ended: 2018-06-06 19:07:01
Those changes were made some time ago. It seems you only checked for updates recently.
No, I do not believe that, when an update announcement appears I will immediately issue it.
Can not imagine that I would have missed an update
Provide the link returned from the grab-logs command so we can see the whole story then.
The logs clearly indicate that 4/30 was the last time updates were run until 6/6.
Correct that was OSMC April update.
We made a couple of quiet changes 3-4 weeks ago to fix a couple of bugs, this was not mentioned on the blog as the changes were very small.
