Hi:
Since I update my system yesterday (raspberry pi3, official power supply, external usb hdd) using
sudo apt-get update
sudo apt-get upgrade
osmc is unable to automount my external hdd.
The log file made with:
sudo journalctl | paste-log
is available here: http://paste.osmc.io/bagusutira
The most strange part in the log is:
Sep 07 11:23:19 osmc udisks-glue[298]: Device file /dev/sda1 inserted
Sep 07 11:23:19 osmc udisks-glue[298]: Device /dev/sda1 did not match any rules.
Sep 07 11:23:19 osmc udisks-glue[298]: brw------- 1 root root 8, 1 Sep 7 11:23 /dev/sda1
When manually mounting the disk works just fine:
sudo mount /dev/sda1 mount_point
What do you suggest to recover automount ?
[EDIT]
Solved ! (???)
After better searching some threads here at the osmc foruns,
I’ve noticed a solution that seems to work
(I’ve updated the original suggested version 1.4.0 to the now available 1.4.4):
wget http://apt.osmc.tv/pool/main/d/diskmount-osmc/diskmount-osmc_1.4.4_all.deb
sudo dpkg -i diskmount-osmc_1.4.4_all.deb
reboot
