it comprises a HDMI interface and a touchscreen interface. While this is fairly easy to get working on raspbian, it seems that the 800x480 is unsupported by OSMC?
Did anyone manage to get the display working with OSMC?
Added this to config.txt:
hdmi_force_hotplug=1
# Next two lines forces audio through the jack - HDMI-audio crashes the display!
hdmi_drive=1
hdmi_ignore_edid_audio=1
#force 800x480 resolution as this is non-standard for HDMI
hdmi_group=2
hdmi_mode=1
hdmi_mode=87
hdmi_cvt 800 480 60 6 0 0 0
# Ensure power to the display
max_usb_current=1
# to get the touch screen working. this will provide an /dev/input/event*
dtoverlay=ads7846,penirq=25
Hi I Have the same case and screen and found (by accident) that when you set the audio to analogue instead of HDMI or HDMI and Analogue the screen is showing perfect.
It could be al little difficult too get there with the blurry screen (you can also attacht the Pi to a HDMI TV to get te setting right.
Thank you for the Config.txt option I didn’t know these settings (I’m just beginning with my Pi life )
didn’t test the touchscreen yet. I hope the LCD driver install script will work. The main problem will be calibrating
I think.
how is your sound through 3.5 jack I hear some kind of noise while playing movies.
