[Solved] Music uPNP connection goes bad
I have my music (primarily albums, etc.) sitting on my Win 10 sys on a local net and access it thru the OSMC/RPI 3 thru a uPNP connection. I typically shut down my Win 10 sys at night. However, the following day, when I try to listen to music it tells me it can’t find the network connection specified and I have to manually re-establish the connection.
Is this normal or is there something else I need to do to keep this connection “persistent” so it always remains valid?
As always, thanks in advance…and cheers…
BUMP!! BUMP!! :slight_smile:
Please post logs.
Sam,
Appreciate the reply and offer of help.
Which log(s) should I post and where would I find them?
Thanks and cheers…
Apologies for the delay in getting back on this.
I ended up solving the problem a different way. I was using Universal Media Server (3rd party) as a source for my music over my local network to the RPI 3/OSMC sys. I disabled UMS and enabled the Win 10 media server functions and settings for the music directory. Now when I shut down/reboot my Win 10 sys, OSMC/RPI has no problems reconnecting.
All is good.
Thanks much for the offer of help.
Please mark as solved.
