For now, i have this informations:
lsmod:
Module Size Used by
8021q 22147 0
garp 7622 1 8021q
stp 2430 1 garp
llc 6031 2 stp,garp
bcm2835_wdt 4081 0
snd_bcm2835 24938 0
snd_pcm 115812 1 snd_bcm2835
snd_timer 26094 1 snd_pcm
snd 78512 3 snd_bcm2835,snd_timer,snd_pcm
bcm2835_gpiomem 4026 0
bcm2835_thermal 2541 0
uio_pdrv_genirq 3885 0
uio 10428 1 uio_pdrv_genirq
fuse 108681 1
ipv6 448018 42
lsconfig:
eth0 Link encap:Ethernet HWaddr b8:27:eb:c5:51:4f
inet addr:192.168.1.8 Bcast:192.168.1.255 Mask:255.255.255.0
UP BROADCAST RUNNING MULTICAST DYNAMIC MTU:1500 Metric:1
RX packets:12497 errors:0 dropped:0 overruns:0 frame:0
TX packets:7272 errors:0 dropped:0 overruns:0 carrier:0
collisions:0 txqueuelen:1000
RX bytes:15171422 (14.4 MiB) TX bytes:686416 (670.3 KiB)
lo Link encap:Local Loopback
inet addr:127.0.0.1 Mask:255.0.0.0
inet6 addr: ::1/128 Scope:Host
UP LOOPBACK RUNNING MTU:65536 Metric:1
RX packets:0 errors:0 dropped:0 overruns:0 frame:0
TX packets:0 errors:0 dropped:0 overruns:0 carrier:0
RX bytes:0 (0.0 B) TX bytes:0 (0.0 B)
connmanctl technologies:
/net/connman/technology/ethernet
Name = Wired
Type = ethernet
Powered = True
Connected = True
Tethering = False
dmesg:
[ 0.000000] Booting Linux on physical CPU 0x0
[ 0.000000] Initializing cgroup subsys cpuset
[ 0.000000] Initializing cgroup subsys cpuacct
[ 0.000000] Linux version 4.4.27-2-osmc (root@vero2a) (gcc version 4.9.2 (Debian 4.9.2-10) ) #1 SMP PREEMPT Sun Oct 30 16:33:55 UTC 2016
[ 0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
[ 0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instruction cache
[ 0.000000] Machine model: Raspberry Pi 3 Model B Rev 1.2
[ 0.000000] cma: Reserved 8 MiB at 0x2e400000
[ 0.000000] Memory policy: Data cache writealloc
[ 0.000000] On node 0 totalpages: 192512
[ 0.000000] free_area_init_node: node 0, pgdat 80bd6380, node_mem_map add64000
[ 0.000000] Normal zone: 1692 pages used for memmap
[ 0.000000] Normal zone: 0 pages reserved
[ 0.000000] Normal zone: 192512 pages, LIFO batch:31
[ 0.000000] [bcm2709_smp_init_cpus] enter (9660->f3003010)
[ 0.000000] [bcm2709_smp_init_cpus] ncores=4
[ 0.000000] PERCPU: Embedded 13 pages/cpu @aefa9000 s23552 r8192 d21504 u53248
[ 0.000000] pcpu-alloc: s23552 r8192 d21504 u53248 alloc=13*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Built 1 zonelists in Zone order, mobility grouping on. Total pages: 190820
[ 0.000000] Kernel command line: 8250.nr_uarts=0 dma.dmachans=0x7f35 bcm2708_fb.fbwidth=720 bcm2708_fb.fbheight=480 bcm2709.boardrev=0xa02082 bcm2709.serial=0xf0c5514f smsc95xx.macaddr=B8:27:EB:C5:51:4F bcm2708_fb.fbswap=1 bcm2709.uart_clock=48000000 vc_mem.mem_base=0x3dc00000 vc_mem.mem_size=0x3f000000 root=/dev/mmcblk0p2 rootfstype=ext4 rootwait quiet osmcdev=rbp2
[ 0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[ 0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[ 0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[ 0.000000] Memory: 741040K/770048K available (8022K kernel code, 440K rwdata, 1872K rodata, 1792K init, 764K bss, 20816K reserved, 8192K cma-reserved)
[ 0.000000] Virtual kernel memory layout:
vector : 0xffff0000 - 0xffff1000 ( 4 kB)
fixmap : 0xffc00000 - 0xfff00000 (3072 kB)
vmalloc : 0xaf800000 - 0xff800000 (1280 MB)
lowmem : 0x80000000 - 0xaf000000 ( 752 MB)
modules : 0x7f000000 - 0x80000000 ( 16 MB)
.text : 0x80008000 - 0x809b1dc8 (9896 kB)
.init : 0x809b2000 - 0x80b72000 (1792 kB)
.data : 0x80b72000 - 0x80be0074 ( 441 kB)
.bss : 0x80be3000 - 0x80ca23ec ( 765 kB)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] Preemptible hierarchical RCU implementation.
[ 0.000000] Build-time adjustment of leaf fanout to 32.
[ 0.000000] NR_IRQS:16 nr_irqs:16 16
[ 0.000000] Architected cp15 timer(s) running at 19.20MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x46d987e47, max_idle_ns: 440795202767 ns
[ 0.000008] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 4398046511078ns
[ 0.000025] Switching to timer-based delay loop, resolution 52ns
[ 0.000262] Console: colour dummy device 80x30
[ 0.000448] console [tty0] enabled
[ 0.000469] Calibrating delay loop (skipped), value calculated using timer frequency… 38.40 BogoMIPS (lpj=192000)
[ 0.000489] pid_max: default: 32768 minimum: 301
[ 0.000770] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.000785] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[ 0.001722] Disabling cpuset control group subsystem
[ 0.001753] Initializing cgroup subsys io
[ 0.001780] Initializing cgroup subsys memory
[ 0.001823] Initializing cgroup subsys devices
[ 0.001841] Initializing cgroup subsys freezer
[ 0.001859] Initializing cgroup subsys net_cls
[ 0.001905] CPU: Testing write buffer coherency: ok
[ 0.001967] ftrace: allocating 19464 entries in 58 pages
[ 0.046986] CPU0: update cpu_capacity 1024
[ 0.047016] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[ 0.047030] [bcm2709_smp_prepare_cpus] enter
[ 0.047178] Setting up static identity map for 0x8240 - 0x8298
[ 0.126557] [bcm2709_boot_secondary] cpu:1 started (0) 18
[ 0.126829] [bcm2709_secondary_init] enter cpu:1
[ 0.126870] CPU1: update cpu_capacity 1024
[ 0.126876] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[ 0.156570] [bcm2709_boot_secondary] cpu:2 started (0) 17
[ 0.156773] [bcm2709_secondary_init] enter cpu:2
[ 0.156794] CPU2: update cpu_capacity 1024
[ 0.156800] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
[ 0.186622] [bcm2709_boot_secondary] cpu:3 started (0) 17
[ 0.186801] [bcm2709_secondary_init] enter cpu:3
[ 0.186822] CPU3: update cpu_capacity 1024
[ 0.186829] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
[ 0.186893] Brought up 4 CPUs
[ 0.186916] SMP: Total of 4 processors activated (153.60 BogoMIPS).
[ 0.186925] CPU: All CPU(s) started in HYP mode.
[ 0.186932] CPU: Virtualization extensions available.
[ 0.187547] devtmpfs: initialized
[ 0.197431] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3 rev 4
[ 0.197785] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[ 0.198590] pinctrl core: initialized pinctrl subsystem
[ 0.199125] NET: Registered protocol family 16
[ 0.203902] DMA: preallocated 4096 KiB pool for atomic coherent allocations
[ 0.226689] cpuidle: using governor ladder
[ 0.256712] cpuidle: using governor menu
[ 0.262536] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[ 0.262549] hw-breakpoint: maximum watchpoint size is 8 bytes.
[ 0.262694] Serial: AMBA PL011 UART driver
[ 0.262823] uart-pl011 3f201000.uart: could not find pctldev for node /soc/gpio@7e200000/uart0_pins, deferring probe
[ 0.262988] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
[ 0.329286] bcm2835-dma 3f007000.dma: DMA legacy API manager at f3007000, dmachans=0x1
[ 0.329747] SCSI subsystem initialized
[ 0.329923] usbcore: registered new interface driver usbfs
[ 0.330012] usbcore: registered new interface driver hub
[ 0.330113] usbcore: registered new device driver usb
[ 0.336838] raspberrypi-firmware soc:firmware: Attached to firmware from 2016-10-13 17:21
[ 0.363559] clocksource: Switched to clocksource arch_sys_counter
[ 0.408336] FS-Cache: Loaded
[ 0.408606] CacheFiles: Loaded
[ 0.420601] NET: Registered protocol family 2
[ 0.421438] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[ 0.421552] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[ 0.421740] TCP: Hash tables configured (established 8192 bind 8192)
[ 0.421833] UDP hash table entries: 512 (order: 2, 16384 bytes)
[ 0.421880] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[ 0.422102] NET: Registered protocol family 1
[ 0.422435] RPC: Registered named UNIX socket transport module.
[ 0.422445] RPC: Registered udp transport module.
[ 0.422454] RPC: Registered tcp transport module.
[ 0.422462] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.518240] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counters available
[ 0.520027] futex hash table entries: 1024 (order: 4, 65536 bytes)
[ 0.520152] audit: initializing netlink subsys (disabled)
[ 0.520201] audit: type=2000 audit(0.489:1): initialized
[ 0.532998] VFS: Disk quotas dquot_6.6.0
[ 0.533316] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
[ 0.535517] FS-Cache: Netfs ‘nfs’ registered for caching
[ 0.536429] NFS: Registering the id_resolver key type
[ 0.536470] Key type id_resolver registered
[ 0.536480] Key type id_legacy registered
[ 0.538868] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 252)
[ 0.539001] io scheduler noop registered
[ 0.539484] io scheduler bfq registered (default)
[ 0.539493] BFQ I/O-scheduler version: v7r7
[ 0.541996] BCM2708FB: allocated DMA memory ee800000
[ 0.542024] BCM2708FB: allocated DMA channel 0 @ f3007000
[ 0.552652] Console: switching to colour frame buffer device 90x30
[ 1.518271] bcm2835-rng 3f104000.rng: hwrng registered
[ 1.518377] vc-cma: Videocore CMA driver
[ 1.518386] vc-cma: vc_cma_base = 0x00000000
[ 1.518396] vc-cma: vc_cma_size = 0x00000000 (0 MiB)
[ 1.518405] vc-cma: vc_cma_initial = 0x00000000 (0 MiB)
[ 1.518638] vc-mem: phys_addr:0x00000000 mem_base=0x3dc00000 mem_size:0x3f000000(1008 MiB)
[ 1.533531] brd: module loaded
[ 1.542061] loop: module loaded
[ 1.542935] vchiq: vchiq_init_state: slot_zero = 0xae880000, is_master = 0
[ 1.544383] Loading iSCSI transport class v2.0-870.
[ 1.545148] usbcore: registered new interface driver smsc95xx
[ 1.545198] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.745429] Core Release: 2.80a
[ 1.745447] Setting default values for core params
[ 1.745470] Finished setting default values for core params
[ 1.945821] Using Buffer DMA mode
[ 1.945832] Periodic Transfer Interrupt Enhancement - disabled
[ 1.945840] Multiprocessor Interrupt Enhancement - disabled
[ 1.945850] OTG VER PARAM: 0, OTG VER FLAG: 0
[ 1.945862] Dedicated Tx FIFOs mode
[ 1.946172] WARN::dwc_otg_hcd_init:1047: FIQ DMA bounce buffers: virt = 0xae814000 dma = 0xee814000 len=9024
[ 1.946201] FIQ FSM acceleration enabled for :
Non-periodic Split Transactions
Periodic Split Transactions
High-Speed Isochronous Endpoints
Interrupt/Control Split Transaction hack enabled
[ 1.946235] dwc_otg: Microframe scheduler enabled
[ 1.946298] WARN::hcd_init_fiq:413: FIQ on core 1 at 0x8057f240
[ 1.946313] WARN::hcd_init_fiq:414: FIQ ASM at 0x8057f5b0 length 36
[ 1.946329] WARN::hcd_init_fiq:439: MPHI regs_base at 0xaf9ee000
[ 1.946393] dwc_otg 3f980000.usb: DWC OTG Controller
[ 1.946432] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number 1
[ 1.946467] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
[ 1.946517] Init: Port Power? op_state=1
[ 1.946525] Init: Power Port (0)
[ 1.946727] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
[ 1.946742] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.946755] usb usb1: Product: DWC OTG Controller
[ 1.946767] usb usb1: Manufacturer: Linux 4.4.27-2-osmc dwc_otg_hcd
[ 1.946779] usb usb1: SerialNumber: 3f980000.usb
[ 1.947637] hub 1-0:1.0: USB hub found
[ 1.947682] hub 1-0:1.0: 1 port detected
[ 1.948284] dwc_otg: FIQ enabled
[ 1.948293] dwc_otg: NAK holdoff enabled
[ 1.948301] dwc_otg: FIQ split-transaction FSM enabled
[ 1.948329] Module dwc_common_port init
[ 1.948567] usbcore: registered new interface driver usb-storage
[ 1.948835] mousedev: PS/2 mouse device common for all mice
[ 1.949255] usbcore: registered new interface driver usbtouchscreen
[ 1.949525] bcm2835-cpufreq: min=600000 max=1200000
[ 1.951164] sdhci: Secure Digital Host Controller Interface driver
[ 1.951169] sdhci: Copyright© Pierre Ossman
[ 1.951338] sdhost: log_buf @ ae813000 (ee813000)
[ 2.003614] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
[ 2.025686] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
[ 2.025694] mmc-bcm2835 3f300000.mmc: DMA channel allocated
[ 2.060441] mmc0: host does not support reading read-only switch, assuming write-enable
[ 2.062312] mmc0: new high speed SDHC card at address 59b4
[ 2.062602] mmcblk0: mmc0:59b4 USD 15.0 GiB
[ 2.063658] sdhci-pltfm: SDHCI platform and OF driver helper
[ 2.063891] ledtrig-cpu: registered to indicate activity on CPUs
[ 2.063953] hidraw: raw HID events driver © Jiri Kosina
[ 2.064047] usbcore: registered new interface driver usbhid
[ 2.064052] usbhid: USB HID core driver
[ 2.064201] mmcblk0: p1 p2
[ 2.064308] Initializing XFRM netlink socket
[ 2.064327] NET: Registered protocol family 17
[ 2.064409] Key type dns_resolver registered
[ 2.064493] Registering SWP/SWPB emulation handler
[ 2.064965] registered taskstats version 1
[ 2.065063] vc-sm: Videocore shared memory driver
[ 2.065071] [vc_sm_connected_init]: start
[ 2.065357] [vc_sm_connected_init]: end - returning 0
[ 2.066512] 3f201000.uart: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud = 0) is a PL011 rev2
[ 2.066701] of_cfs_init
[ 2.066753] of_cfs_init: OK
[ 2.068430] Freeing unused kernel memory: 1792K (809b2000 - 80b72000)
[ 2.144254] Indeed it is in host mode hprt0 = 00021501
[ 2.315701] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 2.321217] fsck: E2fsck run: /bin/e2fsck -p -C 0 /dev/mmcblk0p2
[ 2.321351] fsck: Filesystem UUID: c304425e-d909-4225-a325-920d590a63e1
[ 2.321497] fsck: /dev/mmcblk0p2: clean, 24290/966656 files, 240222/3865088 blocks
[ 2.343848] usb 1-1: new high-speed USB device number 2 using dwc_otg
[ 2.343943] Indeed it is in host mode hprt0 = 00001101
[ 2.543762] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
[ 2.543775] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.544290] hub 1-1:1.0: USB hub found
[ 2.544345] hub 1-1:1.0: 5 ports detected
[ 2.823604] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
[ 2.923804] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
[ 2.923818] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
[ 2.926357] smsc95xx v1.0.4
[ 2.985302] smsc95xx 1-1.1:1.0 eth0: register ‘smsc95xx’ at usb-3f980000.usb-1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:c5:51:4f
[ 3.465248] random: systemd: uninitialized urandom read (16 bytes read, 66 bits of entropy available)
[ 3.466777] systemd[1]: systemd 215 running in system mode. (+PAM +AUDIT +SELINUX +IMA +SYSVINIT +LIBCRYPTSETUP +GCRYPT +ACL +XZ -SECCOMP -APPARMOR)
[ 3.466948] systemd[1]: Detected architecture ‘arm’.
[ 3.512760] NET: Registered protocol family 10
[ 3.513598] systemd[1]: Inserted module ‘ipv6’
[ 3.521224] systemd[1]: Set hostname to .
[ 3.587814] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 66 bits of entropy available)
[ 3.674547] random: systemd: uninitialized urandom read (16 bytes read, 68 bits of entropy available)
[ 3.675120] random: systemd: uninitialized urandom read (16 bytes read, 68 bits of entropy available)
[ 3.675730] random: systemd: uninitialized urandom read (16 bytes read, 68 bits of entropy available)
[ 3.687700] random: systemd: uninitialized urandom read (16 bytes read, 68 bits of entropy available)
[ 3.688082] random: systemd: uninitialized urandom read (16 bytes read, 68 bits of entropy available)
[ 3.688150] random: systemd: uninitialized urandom read (16 bytes read, 68 bits of entropy available)
[ 3.719913] random: systemd: uninitialized urandom read (16 bytes read, 68 bits of entropy available)
[ 3.719972] random: systemd: uninitialized urandom read (16 bytes read, 68 bits of entropy available)
[ 3.789482] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
[ 3.789611] systemd[1]: Found ordering cycle on basic.target/start
[ 3.789622] systemd[1]: Found dependency on sysinit.target/start
[ 3.789632] systemd[1]: Found dependency on kbd.service/start
[ 3.789643] systemd[1]: Found dependency on remote-fs.target/start
[ 3.789653] systemd[1]: Found dependency on remote-fs-pre.target/start
[ 3.789662] systemd[1]: Found dependency on connman.service/start
[ 3.789671] systemd[1]: Found dependency on dbus.service/start
[ 3.789680] systemd[1]: Found dependency on basic.target/start
[ 3.789689] systemd[1]: Breaking ordering cycle by deleting job kbd.service/start
[ 3.789700] systemd[1]: Job kbd.service/start deleted to break ordering cycle starting with basic.target/start
[ 3.789828] systemd[1]: Found ordering cycle on basic.target/start
[ 3.789839] systemd[1]: Found dependency on sysinit.target/start
[ 3.789849] systemd[1]: Found dependency on rpcbind.service/start
[ 3.789860] systemd[1]: Found dependency on network-online.target/start
[ 3.789869] systemd[1]: Found dependency on network.target/start
[ 3.789878] systemd[1]: Found dependency on connman.service/start
[ 3.789887] systemd[1]: Found dependency on dbus.service/start
[ 3.789896] systemd[1]: Found dependency on basic.target/start
[ 3.789906] systemd[1]: Breaking ordering cycle by deleting job rpcbind.service/start
[ 3.789917] systemd[1]: Job rpcbind.service/start deleted to break ordering cycle starting with basic.target/start
[ 3.791090] systemd[1]: Starting Forward Password Requests to Wall Directory Watch.
[ 3.791234] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 3.791314] systemd[1]: Starting Arbitrary Executable File Formats File System Automount Point.
[ 3.791544] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 3.791588] systemd[1]: Starting Encrypted Volumes.
[ 3.791621] systemd[1]: Reached target Encrypted Volumes.
[ 3.791668] systemd[1]: Starting Dispatch Password Requests to Console Directory Watch.
[ 3.791769] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 3.791802] systemd[1]: Starting Paths.
[ 3.791834] systemd[1]: Reached target Paths.
[ 3.791867] systemd[1]: Starting Swap.
[ 3.791898] systemd[1]: Reached target Swap.
[ 3.791931] systemd[1]: Expecting device dev-mmcblk0p1.device…
[ 3.791967] systemd[1]: Starting Root Slice.
[ 3.792038] systemd[1]: Created slice Root Slice.
[ 3.792072] systemd[1]: Starting User and Session Slice.
[ 3.792191] systemd[1]: Created slice User and Session Slice.
[ 3.792225] systemd[1]: Starting Delayed Shutdown Socket.
[ 3.792308] systemd[1]: Listening on Delayed Shutdown Socket.
[ 3.792342] systemd[1]: Starting /dev/initctl Compatibility Named Pipe.
[ 3.792434] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[ 3.792467] systemd[1]: Starting Journal Socket (/dev/log).
[ 3.792554] systemd[1]: Listening on Journal Socket (/dev/log).
[ 3.792597] systemd[1]: Starting udev Control Socket.
[ 3.792670] systemd[1]: Listening on udev Control Socket.
[ 3.792710] systemd[1]: Starting udev Kernel Socket.
[ 3.792771] systemd[1]: Listening on udev Kernel Socket.
[ 3.792813] systemd[1]: Starting Journal Socket.
[ 3.792903] systemd[1]: Listening on Journal Socket.
[ 3.792959] systemd[1]: Starting System Slice.
[ 3.793060] systemd[1]: Created slice System Slice.
[ 3.793101] systemd[1]: Starting Restore / save the current clock…
[ 3.823961] systemd[1]: Mounting POSIX Message Queue File System…
[ 3.825658] systemd[1]: Mounting Debug File System…
[ 3.827162] systemd[1]: Starting udev Coldplug all Devices…
[ 3.829146] systemd[1]: Starting Create list of required static device nodes for the current kernel…
[ 3.884824] systemd[1]: Starting Load Kernel Modules…
[ 3.900150] systemd[1]: Started Set Up Additional Binary Formats.
[ 3.900237] systemd[1]: Mounted Huge Pages File System.
[ 3.900272] systemd[1]: Starting LSB: NFS support files common to client and server…
[ 3.901570] systemd[1]: Starting Journal Service…
[ 3.903111] systemd[1]: Started Journal Service.
[ 3.993163] fuse init (API version 7.23)
[ 4.034893] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 4.207528] systemd-udevd[178]: starting version 215
[ 4.430804] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f200000
[ 4.539469] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
[ 4.742082] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[ 4.807570] uart-pl011 3f201000.uart: no DMA platform data
[ 5.475172] systemd-journald[159]: Received request to flush runtime journal from PID 1
[ 6.064797] smsc95xx 1-1.1:1.0 eth0: hardware isn’t capable of remote wakeup
[ 6.064941] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[ 7.651677] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 7.652703] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xCDE1
[ 7.805487] 8021q: 802.1Q VLAN Support v1.8
[ 10.407844] Console: switching to colour dummy device 80x30
[ 10.567498] random: nonblocking pool is initialized
