I’m not too sure what is relevant to this problem so apologies if I go overboard providing information.
I’m running Emby as a directplay backend server on CentOS7 with a 1GB ethernet link to a Gigabit network switch. I have two Raspberry Pi 3s running the latest level of osmc (but had the same problem on previous versions) and 2.3.46 of Emby for Kodi. One is wired into the switch the other is WiFi.
I have TVs/Movies (SD), captured analog camcorder footage and later HD digital camcorder footage that all plays fine on this setup.
I have further footage from an SD digital camcorder that I am having problems with. I have tried using it as ‘.dv’ or transcoded to ‘.mpg’ without any obvious difference.
When I play it on either Pi the sound starts before the video but is kind of crackly, sometimes the video doesn’t start at all but if it does it is jumpy. The sound either stops or progresses to a kind of 100 beats/min drum effect before stopping. The onscreen display switches between a predicted ‘end of playback’ time or ‘buffering…’. Sometimes, but not always, there is a message about the source being too slow for continuous playback. That seems unlikely since all of the other media works fine.
However the same media plays fine on the web interface for Emby on a PC, and Emby apps on android phone or iPad; again this looks like the source is plenty fast enough.
Emby support says because it is using DirectPlay they can’t really see any useful diagnostic information. So, I’m hoping that you may be able to give me some idea what the issue is; a media issue, a Pi or OSMC problem?
I’m not sure what further information would be helpful but I can drop an example copy of the media on a shared service if that would help.
Thanks.
