Hello all! I recently found an old 1GB SD card, and I challenged myself to put a functional OSMC install on this little thing. I have also bigger (8 GB) card ready, but I would like (just for fun) make some modification to the partition layout and have some more space on / partition.
So, after a fresh install I have roughly a 255 MB /boot partition and 750 MB /. /boot has only 25 MB on it, while / after (apt-get update and installing YouTube and Jupiter Broadcasting leaves me with only 12 MB of free space. Not really much, since I would like to install some additional stuff (rsync, tmux, maybe some other stuff) and expect log files to grow after some time. So I figured, that I could shrink the /boot partition to 75 MB (space for 3 kernel images) and expand the /, which would give me at least 150 MB extra space. More than enough for me. So, I dd’ed the CD card to have an image backup, rsynced /boot and / to separate directories, created new partition scheme with fdisk, created filesystems (vfat for /boot, ext4 for /) and copied over the contents of each directory separately. Since the /boot partition didn’t have the bootable flag set, I didn’t change that either. I put it back to Raspberry, but no success.
Then, I tried two different things - i dd’ed the 447 bits from the original backup image to the SD (that is where the boot code should reside, right?), so I had boot code + new partition layout. No success. Then, I tried to install GRUB via grub-install form my Xubuntu laptop, but still no success.
I have the backed up image that is ready for action, but just out of curiosity I have a question - what am I doing wrong? Does OSMC doesn’t use GRUB?
Thanks for taking the time to read that longish post.I would appreciate any of your suggestions.
