When I run an update of the video library I get messages in the log telling me that some files/directories are not found. I don’t have a problem with that because they are not there and are not supposed to be there. How do I get rid of these messages? They will not go away with a “clean” and I have completely rebuilt the videos and tv files by removing the sources and adding them again.
I believe this is normal and expected behavior. I don’t think the clean library function bothers removing old source folders, just missing files. I think the only way to remove these outside of deleting your library db and scraping again would be to manually edit the database. I think there might be a way to do it with the Texture Cache Maintenance utility as well but I’ve not tried to do that one myself.
Allow us to help you
It goes without saying that the better we can understand a problem you might be having, the more likely we can help you fix it. When you make a post, you may be asked to provide a log. You can read more about obtaining logs on our wiki here
These are best uploaded to a Pastebin website. We recommend you use our official Pastebin which is hosted at paste.osmc.io as we can regularly process the pastes to identify common issues and in turn improve our product.
Although I think getting rid of old streaming links was the original intent from many years ago, I think if you had looked a bit farther in that thread it shows it has extended well past that. But, after your reply I decided to go ahead and install it on my PC and let it run and take a look at the log of what it found for removal. The list contained both online and local paths for things that were no longer valid links. In the settings I also saw options for manually specifying paths for removal among many other advanced options.
I didn’t choose the option to have it actually clean as it also pegged some things I didn’t want removed and I didn’t see the point. I’m using a MySQL db and I didn’t feel like going through the trouble in case something went sideways. A regular Kodi db it can backup as part of the process. I suppose you can evaluate the risk on your own based upon posts in that Kodi thread for it.
What happens if you manually create these directories, scrape again, remove them and finally process another scraping run?
Just from the semantic it looks like you accidentally created some videos stuff in your mounted audio path in the past?
It could be more helpful to provide a standard log collection:
reproduce the issue
Tried to reproduce this here by creating a subdirectory, place a movie into it, update the video library, remove the directory and update the lib, again … and cannot provoke the error.
Maybe this entry is different from you setup, in my advancedsettings.xml I use
