Hi there,
just installed OSMC RC on my RPi2 after successfully playing around with Alpha 4.
However, now it seems that my favorite skins (Eminence, Aeon Nox) which I had installed on Alpha 4 are marked (among others) as incompatible.
Am I missing something here?
Force an addon/repo update from System>addon menu
I did “Check for updates”, which now shows (Last updated 15-03-2015 17:24).
Skins still are incompatible. Or do you mean a different “addon/repo update”?
Thought so.
Still - skins are incompatible.
Any further suggestions?
Kodi add-on repository shows version 2.1.32 - if that is any help?
EDIT: The addon itself shows “dependencies not met - contact addon author”
Any chance I can find out which dependencies are not met?
I don’t know what happened, but it worked automagically when I came home this evening and tried again.
So: Closed
