I have been looking around to change the settings level from standard to expert. Everywhere i read, it says “press left arrow in any settings screen to change it”, but i do not see any option to change the settings level. Can someone help? Am i missing something obvious? I am on osmc running kodi 17.1
Using OSMC skin?
Yes, i am using the default OSMC skin.
I finally figured out how to change it. Used the up/down arrow keys in one of the settings screen until the “Settings Level” at the bottom is highlighted white, then pressed ‘Enter’ key to change the value to “advanced”, “expert”, or back to “standard”
