Installed a new skin, applied it, it crashed and from there I was on a boot loop. Now the problem is I can’t ssh into OSMC; I was using my phone’s wifi hotspot, the ethernet is disabled on start up and I don’t know how to enable it by default.
So I am running a NOOB install, I was able to ssh into raspbian and delete the skin folder, as well as guisettings.xml with no luck.
Although I managed to get into the console, manually enabling the ethernet, starting ssh and finally could grab these logs :
http://paste.osmc.io/heyudulixu
http://paste.osmc.io/cipuyiduna
I tried running fsck but don’t know how to properly use it, the disk are always already mounted…
So I guess the solution to my problem is running fsck; how do I do it correctly ? And how can I enable ethernet on start up ?
Thank you so much for any help in advance!
EDIT : alright fixed it by renaming .kodi…
