Hello,
I am in trouble for mkv video in 1080p which stutter audio and video too. The strange thing is about others video .mkv and 1080p too which work fine, I don’t know why the video are very similar in audio and video quality. I didn’t change default settings and the videos are inside a HDD connected via USB to Raspberry PI.
EDIT :
This video works : VideoID : 1Format - Pastebin.com
This video doesn’t work : VideoID : 1Format - Pastebin.com
Thanks in advance!
CaNsA
26 March 2015 18:04
2
Please provide the media info for the files you are having trouble with along with debug logs.
http://kodi.wiki/view/Log_file
http://kodi.wiki/view/MediaInfo
CaNsA
26 March 2015 18:20
4
Thanks, so I can not see them in any way ? Is there a way to reproduce them in a low quality ?
CaNsA
26 March 2015 18:28
6
Hit up google for Handbrake.
I mean without convert them
CaNsA
26 March 2015 18:33
8
They will need to be converted/recoded either on the fly (transcoding) or you will need to convert/recode them.
Is it possible to transcode them with raspberry PI ? I would find a way to have my file working without the use of PC
CaNsA
26 March 2015 18:41
10
I suppose it might be able to transcode them on one pi, then feed the stream to another pi.
I have no idea why you would do that though, when you could just recode them on a pc and copy the files over to the USB hdd.
I would avoid to duplicate files because I want the best coding resolution for my PC but I will follow you way, thanks.
CaNsA
26 March 2015 18:44
12
Keep the original file on your pc then…
Transcoding a full length video is likely to be VERY slow on a Pi, it wouldn’t make any sense to do it there.
CaNsA
26 March 2015 19:00
14
I am locking this thread as OSMC is not geared towards on-pi transcoding and the original question has been answered and explained.
