Hello guys,
i recently bought a Vero 4k and am currently busy setting it up.
The first problem i ran into is the wireless network speed. It only offers half the speed vs. wired connections. The speed i am able to achieve is not enough to stream huge 4k files (roughly 625MB per Minute are needed / you’ll see later why i calculated in Mb / minute)
My Hardware:
Synology Diskstation 918+ - referred as NAS
Synology RT1900AC - referred as Router
Vero 4k - referred as Vero
The Router and the Vero are able to talk 802.11ac. With theoretical network speeds of 1.300 Mbit/s.
I know theoretical != real world, but read on, i’m not even close to half the speed.
What i’ve done:
To minimize interference and bad connections, i placed the vero on the same desk as the router.
To set a benchmark, i started the measuring using a wired connection directly to the router, on which my NAS is also connected. To exclude the “smart connect” bamboozling with 2,4 and 5 GHz, i disabled all those functions, running 2,4 GHz only.
I Installed a debian vm on my NAS to install iperf. I also installed iperf on the Vero 4k.
Because of port assigning problems, i can only test one way → the Vero as iperf server, the NAS as client.
The results (wired connection) while using iperf -t60 -c 192.168.178.128
as command are as follows:
Client connecting to 192.168.178.128, TCP port 5001 TCP window size: 85.0 KByte (default) ------------------------------------------------------------ [ 3] local 172.17.0.2 port 58784 connected with 192.168.178.128 port 5001 [ ID] Interval Transfer Bandwidth [ 3] 0.0-60.1 sec 677 MBytes 94.5 Mbits/sec
running it several times does always result in this result.
If i am not mistaken - is my result close to the maximum possible over the wired connection (vero limitation).
When using the wireless connection i only get the following result:
Client connecting to 192.168.178.126, TCP port 5001 TCP window size: 85.0 KByte (default) ------------------------------------------------------------ [ 3] local 172.17.0.2 port 33462 connected with 192.168.178.126 port 5001 [ ID] Interval Transfer Bandwidth [ 3] 0.0-60.0 sec 317 MBytes 44.3 Mbits/sec
That beeing said - the NAS does support faster speeds as 44.3 MBits/sec, and the connection should not be as slow as it is.
I can get much faster read/write speeds on the NAS over wifi using different devices.
Does anyone have a clue how to move forward?
Best regards
