did you check my log?
It’s normal. Vero has to convert to RGB internally then picks the ‘highest’ colourspace your display supports for output.
thank you for the information.
Did someone check my log?
I am still get the rc. local error after i did the hotfix
Please try this hotfix code
luyapupula
sorry. after restart i got the rc.local error again.
here is the debug log, hope u can help me
Please run the following:
ls -l /etc/rc.local
sudo apt-get install bsdmainutils
hd /etc/rc.local | paste-log
and let us know the URL returned from the third command.
the version in the hotfix looks good. anyway, just deleting rc.local should have the desired result I think.
sudo rm /etc/rc.local
thank you. this worked now. after reboot i didnt get a error message.
