Sound for 1sec after pause
hi guys!
Since last update (krypton) my OSMC on the pi2 acts weird, when i pause a movie or search for a subtitle i can hear the sound of the movie for 1 second.
Could you please fix this?
Without debug enabled logs that demonstrate the issue, we have no idea where to look for the cause or even determine if the problem is with OSMC or Kodi. So… quite low on the rather extensive “to do” list. Even so, I should think 1 second of audio after pause would hardly be insufferable for 99.9% users.
Also, it’s quite short sighted of you to simply assume that this affects everyone and is not simply due to some specific configuration of settings or hardware in your setup.
