Hello everyone. I have just installed a media centre running on OSMC. i wanted specifically to have Netflix on my not smart TV. Almost everything works fine. I have two issues:
- the sound is not very loud (I have to put the volume up on the TV).
- Bluetooth is pairing with my speakers but no sound is coming out.
All help is appreciated.
Do you have a keyboard attached? then try to +
Did you install A2DP App
Thank you very much fzinken. My bluetooth is working with A2DP. The volume with the + is up to 100%.
I just have to put the volume up on my TV.
