OSMC has been working well for a year, so I brought the device on vacation.
Device boots up with message:
waiting for root filesystem device /dev/mmcblp02
/dev/mmcbl0p2: recovering journal
Then displays the OSMC splash screen and then the display indicates no signal.
The pi responds to ping / SSH login.
dmesg: http://paste.debian.net/704020/
- Has anyone seen this problem?
- What is the next-step for diagnosing root-cause of issue?
I have not compared the dmesg with a working one (no easy access from here) but this looks suspicious
3.953952] systemd[1]: Cannot add dependency job for unit display-manager.service, ignoring: Unit display-manager.service failed to load: No such file or directory.
While that indicates that you had an unclean shutdown but it should not impact the Kodi display.
- Have you tried to use a different HDMI cable?
- What do you have in config.txt?
cat /boot/config.txt | paste-log
- Also what is the output from
tvservice -s
tvservice -m CEA
tvservice -m DMT
- Provide full logs via grab-logs -A
- You might want to install VNCserver to see if Kodi is running and which Video Mode used
No that is a normal warning on all OSMC systems
Thanks for the good diagnostics commands. I am interested in how you interpret these / what you are looking for to diagnose:
osmc@osmc1:~$ tvservice -s
state 0x12000a [HDMI CEA (16) RGB lim 16:9], 1920x1080 @ 59.94Hz, progressive
osmc@osmc1:~$ tvservice -m CEA
Group CEA has 8 modes:
mode 1: 640x480 @ 60Hz 4:3, clock:25MHz progressive
mode 2: 720x480 @ 60Hz 4:3, clock:27MHz progressive
mode 3: 720x480 @ 60Hz 16:9, clock:27MHz progressive
(native) mode 4: 1280x720 @ 60Hz 16:9, clock:74MHz progressive
mode 5: 1920x1080 @ 60Hz 16:9, clock:74MHz interlaced
mode 16: 1920x1080 @ 60Hz 16:9, clock:148MHz progressive
mode 32: 1920x1080 @ 24Hz 16:9, clock:74MHz progressive
mode 34: 1920x1080 @ 30Hz 16:9, clock:74MHz progressive
osmc@osmc1:~$ tvservice -m DMT
Group DMT has 15 modes:
mode 4: 640x480 @ 60Hz 4:3, clock:25MHz progressive
mode 5: 640x480 @ 72Hz 4:3, clock:31MHz progressive
mode 6: 640x480 @ 75Hz 4:3, clock:31MHz progressive
mode 8: 800x600 @ 56Hz 4:3, clock:36MHz progressive
mode 9: 800x600 @ 60Hz 4:3, clock:40MHz progressive
mode 10: 800x600 @ 72Hz 4:3, clock:50MHz progressive
mode 11: 800x600 @ 75Hz 4:3, clock:49MHz progressive
mode 16: 1024x768 @ 60Hz 4:3, clock:65MHz progressive
mode 17: 1024x768 @ 70Hz 4:3, clock:75MHz progressive
mode 18: 1024x768 @ 75Hz 4:3, clock:78MHz progressive
mode 23: 1280x768 @ 60Hz 15:9, clock:79MHz progressive
mode 35: 1280x1024 @ 60Hz 5:4, clock:108MHz progressive
mode 36: 1280x1024 @ 75Hz 5:4, clock:135MHz progressive
(prefer) mode 39: 1360x768 @ 60Hz 16:9, clock:85MHz progressive
mode 51: 1600x1200 @ 60Hz 4:3, clock:162MHz progressive
osmc@osmc1:~$ grab-logs -A
Logs successfully uploaded.
Logs available at http://paste.osmc.io/eqoyaxalip
