I have my SQL library on a Synology NAS, which is shared between 2 OSMC installs on 2x Rpi 3.
I had gotten some help in getting the library set up but it just stopped working today.
I didn’t change anything (that I’m aware of). Only unusual thing that happened was a short power outage, which required me to manually restart the NAS.
Any thoughts on where I should be looking to get the library back up and running again?
Thanks guys!
I did check the IP of the NAS and it was the same. I rebooted the Pi and enabled the debug logging thing, in order to generate a clean Log file.
When it rebooted, everything was working again!!?! The old “turn-it-off-then-turn-it-on-again” (TIOTIOA?) routine. Thanks for your responses and advice, as always.
