How to migrate to new SSD from 2GB to 8-16GB and keep data?
I used 2GB SSD because it was the only SSD I found at home when received my RP2 and it was fine for a while. Now I think it has no free space even to boot. It was close to 0 for some time and now it does not boot anymore. Can’t log via SSH too. Sad face showing up.
I will get new SSD, but don’t want to start from fresh install. Anyhow I can upgrade?
While I assume you refering to an SD Card and not a SSD, or?
If that is the case it is as easy as @Dilligaf wrote. Basically get the gparted live http://gparted.org/livecd.php but it on a PC and you have all tools you need to make that migration and upgrade.
