SSH won't connect
I used to be able too Connect, but now I can’t and osmc user is not found and connection refused. Am I missing something?
I try to connect via ip
Ssh 192.168.1.129
Asked for user, I type in, says refused. Is there a way to check users or a back door I can look into?
Which SSH client (including version) are you using?
Have you tried ssh osmc@192.168.1.129?
Try to log in directly on the box by exit Kodi and press ESC.
So I don’t have a keyboard but I reset box (which sucks because I need to redo Hyperion) but now it works. IDK what the issue was.
