Is there any way to start a picture/video slideshow through SSH? Basically I want to keep something running all the time without needing to be there locally.
Also, is there a way to keep it on repeat and to make sure the screen never goes to sleep?
Thanks for the help everyone!
Have a look at kodi-send and the builtin functions.
Ok, thanks.
On another note, any idea if you can use VNC to remote into the actual GUI instead of just using SSH into the terminal?
Search for VNC server.
Did try the big magnifying glass in the top right? Try it, get to know it, become intimately familiar with it. It’s perhaps the most valuable tool we can provide.
