Stop start of transmission on boot
Hi, I have installed tranmission-daemon on OSMC system in Raspberry Pi 2.
It start when I boot the system (power off or restart) and I need that It don´t start because I have to start with my script that mount a external NAS as respositories of transmission.
I tried with:
  • “sudo update-rc.d -f transmission-daemon remove”
  • removing the transmission-daemon from /etc/init.d
/etc/rc.local only have “exit 0”
Some ideas about how can stop the start of transmission-daemon on boot?
sudo systemctl disable transmission.service
The commands you’re trying to use are legacy sys v init commands - OSMC uses systemd init.
Also, you can enable/disable services installed from the App Store in the services section of My OSMC.
Thanks for your answer but it don´t work in my system.
I reboot the system and transmission start in the boot.
I installed transmission-daemon using apt-get and OSMC app store don´t consider transmissión installed.
It’s possible that the standard version of transmission doesn’t use a systemd service. Try using the App Store version instead.
ok, I will try.
