This is my last log after strange reboot :
1:58:16.213 T:3000190848 NOTICE: special://profile/ is mapped to: special://masterprofile/
21:58:16.213 T:3000190848 NOTICE: -----------------------------------------------------------------------
21:58:16.213 T:3000190848 NOTICE: Starting Kodi (17.1-RC1). Platform: Linux x86 32-bit
21:58:16.213 T:3000190848 NOTICE: Using Release Kodi x32 build
21:58:16.213 T:3000190848 NOTICE: Kodi compiled Feb 9 2017 by GCC 4.9.2 for Linux x86 32-bit version 3.16.39 (200743)
21:58:16.213 T:3000190848 NOTICE: Running on Open Source Media Center 2017.02-2, kernel: Linux x86 32-bit version 4.2.3-22-osmc
21:58:16.230 T:3000190848 NOTICE: FFmpeg version/source: ffmpeg-3.1-kodi
21:58:16.230 T:3000190848 NOTICE: Host CPU: Genuine Intel(R) processor 1.00GHz, 1 core available
21:58:16.230 T:3000190848 NOTICE: special://xbmc/ is mapped to: /usr/share/kodi
21:58:16.230 T:3000190848 NOTICE: special://xbmcbin/ is mapped to: /usr/lib/kodi
21:58:16.230 T:3000190848 NOTICE: special://xbmcbinaddons/ is mapped to: /usr/lib/kodi/addons
21:58:16.230 T:3000190848 NOTICE: special://masterprofile/ is mapped to: /home/osmc/.kodi/userdata
21:58:16.230 T:3000190848 NOTICE: special://envhome/ is mapped to: /home/osmc
21:58:16.230 T:3000190848 NOTICE: special://home/ is mapped to: /home/osmc/.kodi
21:58:16.230 T:3000190848 NOTICE: special://temp/ is mapped to: /home/osmc/.kodi/temp
21:58:16.230 T:3000190848 NOTICE: special://logpath/ is mapped to: /home/osmc/.kodi/temp
21:58:16.230 T:3000190848 NOTICE: The executable running is: /usr/lib/kodi/kodi.bin
21:58:16.230 T:3000190848 NOTICE: Local hostname: osmc
21:58:16.230 T:3000190848 NOTICE: Log File is located: /home/osmc/.kodi/temp//kodi.log
21:58:16.230 T:3000190848 NOTICE: -----------------------------------------------------------------------
21:58:16.395 T:3000190848 ERROR: DBus: Error org.freedesktop.DBus.Error.ServiceUnknown - The name org.freedesktop.UPower was not provided by any .service files
21:58:16.522 T:3000190848 NOTICE: load settings…
21:58:17.128 T:3000190848 NOTICE: Found 1 Lists of Devices
21:58:17.128 T:3000190848 NOTICE: Enumerated ALSA devices:
21:58:17.128 T:3000190848 NOTICE: Device 1
21:58:17.128 T:3000190848 NOTICE: m_deviceName : @
21:58:17.128 T:3000190848 NOTICE: m_displayName : Default (HDA Intel ALC889A Analog)
21:58:17.128 T:3000190848 NOTICE: m_displayNameExtra:
21:58:17.128 T:3000190848 NOTICE: m_deviceType : AE_DEVTYPE_PCM
21:58:17.128 T:3000190848 NOTICE: m_channels : FL,FR
21:58:17.128 T:3000190848 NOTICE: m_sampleRates : 48000
21:58:17.128 T:3000190848 NOTICE: m_dataFormats : AE_FMT_S32NE
21:58:17.128 T:3000190848 NOTICE: m_streamTypes : No passthrough capabilities
21:58:17.128 T:3000190848 NOTICE: Device 2
21:58:17.129 T:3000190848 NOTICE: m_deviceName : @:CARD=Intel,DEV=0
21:58:17.129 T:3000190848 NOTICE: m_displayName : HDA Intel
21:58:17.129 T:3000190848 NOTICE: m_displayNameExtra: ALC889A Analog
21:58:17.129 T:3000190848 NOTICE: m_deviceType : AE_DEVTYPE_PCM
21:58:17.129 T:3000190848 NOTICE: m_channels : FL,FR
21:58:17.129 T:3000190848 NOTICE: m_sampleRates : 48000
21:58:17.129 T:3000190848 NOTICE: m_dataFormats : AE_FMT_S32NE
21:58:17.129 T:3000190848 NOTICE: m_streamTypes : No passthrough capabilities
21:58:17.129 T:3000190848 NOTICE: Device 3
21:58:17.129 T:3000190848 NOTICE: m_deviceName : iec958:CARD=Intel,DEV=0
21:58:17.129 T:3000190848 NOTICE: m_displayNameExtra: ALC889A Digital S/PDIF
21:58:17.129 T:3000190848 NOTICE: m_deviceType : AE_DEVTYPE_IEC958
21:58:17.129 T:3000190848 NOTICE: m_sampleRates : 44100,48000,88200,96000,192000
21:58:17.129 T:3000190848 NOTICE: m_dataFormats : AE_FMT_RAW,AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE
21:58:17.129 T:3000190848 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_512
21:58:17.129 T:3000190848 NOTICE: Device 4
21:58:17.152 T:3000190848 NOTICE: m_deviceName : hdmi:CARD=Intel,DEV=0
21:58:17.152 T:3000190848 NOTICE: m_displayName : HDA Intel
21:58:17.152 T:3000190848 NOTICE: m_displayNameExtra: HDMI
21:58:17.152 T:3000190848 NOTICE: m_deviceType : AE_DEVTYPE_HDMI
21:58:17.152 T:3000190848 NOTICE: m_channels : FL,FR,LFE,FC,BC,BL,BR,FLOC,FROC,BLOC,BROC,TFC,TC,TFL,TFR,UNKNOWN1
21:58:17.152 T:3000190848 NOTICE: m_sampleRates : 32000,44100,48000,88200,96000,176400,192000
21:58:17.152 T:3000190848 NOTICE: m_dataFormats : AE_FMT_S32NE,AE_FMT_S16NE,AE_FMT_S16LE,AE_FMT_RAW
21:58:17.152 T:3000190848 NOTICE: m_streamTypes : STREAM_TYPE_AC3,STREAM_TYPE_DTSHD,STREAM_TYPE_DTSHD_CORE,STREAM_TYPE_DTS_1024,STREAM_TYPE_DTS_2048,STREAM_TYPE_DTS_512,STREAM_TYPE_EAC3,STREAM_TYPE_TRUEHD
21:58:17.244 T:3000190848 NOTICE: Loaded settings file from special://xbmc/system/advancedsettings.xml
21:58:17.245 T:3000190848 NOTICE: Contents of special://xbmc/system/advancedsettings.xml are…
<?xml version="1.0" encoding="UTF-8" ?>
0
1
540
720
false
0
30
2
21:58:17.247 T:3000190848 NOTICE: No settings file to load (special://masterprofile/advancedsettings.xml)
21:58:17.247 T:3000190848 NOTICE: Default Video Player: VideoPlayer
21:58:17.247 T:3000190848 NOTICE: Default Audio Player: paplayer
21:58:17.247 T:3000190848 NOTICE: Disabled debug logging due to GUI setting. Level 0.
21:58:17.247 T:3000190848 NOTICE: Log level changed to “LOG_LEVEL_NORMAL”
21:58:17.247 T:3000190848 NOTICE: CMediaSourceSettings: loading media sources from special://masterprofile/sources.xml
21:58:17.262 T:3000190848 NOTICE: Loading player core factory settings from special://xbmc/system/playercorefactory.xml.
21:58:17.263 T:3000190848 NOTICE: Loaded playercorefactory configuration
21:58:17.264 T:3000190848 NOTICE: Loading player core factory settings from special://masterprofile/playercorefactory.xml.
21:58:17.264 T:3000190848 NOTICE: special://masterprofile/playercorefactory.xml does not exist. Skipping.
21:58:17.711 T:3000190848 NOTICE: Running database version Addons27
21:58:21.612 T:3000190848 NOTICE: ADDONS: Using repository repository.xbmc.org
21:58:21.613 T:3000190848 NOTICE: ADDONS: Using repository repository.shani
21:58:23.242 T:3000190848 NOTICE: Checking resolution 16
21:58:23.595 T:3000190848 ERROR: failed to initialize egl display
21:58:23.596 T:3000190848 NOTICE: Using visual 0x28
21:58:23.663 T:3000190848 NOTICE: GL_VENDOR = NVIDIA Corporation
21:58:23.663 T:3000190848 NOTICE: GL_RENDERER = GeForce Go 7300/PCIe/SSE2
21:58:23.663 T:3000190848 NOTICE: GL_VERSION = 2.1.2 NVIDIA 304.134
21:58:23.663 T:3000190848 NOTICE: GL_SHADING_LANGUAGE_VERSION = 1.20 NVIDIA via Cg compiler
21:58:23.663 T:3000190848 NOTICE: GL_EXTENSIONS = GL_ARB_color_buffer_float GL_ARB_compressed_texture_pixel_storage GL_ARB_conservative_depth GL_ARB_copy_buffer GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_draw_buffers GL_ARB_ES2_compatibility GL_ARB_explicit_attrib_location GL_ARB_fragment_program GL_ARB_fragment_program_shadow GL_ARB_fragment_shader GL_ARB_framebuffer_object GL_ARB_get_program_binary GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging GL_ARB_internalformat_query GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multisample GL_ARB_multitexture GL_ARB_occlusion_query GL_ARB_occlusion_query2 GL_ARB_pixel_buffer_object GL_ARB_point_parameters GL_ARB_point_sprite GL_ARB_provoking_vertex GL_ARB_robustness GL_ARB_sampler_objects GL_ARB_separate_shader_objects GL_ARB_shader_objects GL_ARB_shading_language_100 GL_ARB_shading_language_420pack GL_ARB_shading_language_include GL_ARB_shadow GL_ARB_sync GL_ARB_texture_border_clamp GL_ARB_texture_compression GL_ARB_texture_cube_map GL_ARB_texture_env_add GL_ARB_texture_env_combine GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float GL_ARB_texture_mirrored_repeat GL_ARB_texture_non_power_of_two GL_ARB_texture_rectangle GL_ARB_texture_rg GL_ARB_texture_storage GL_ARB_texture_swizzle GL_ARB_timer_query GL_ARB_transpose_matrix GL_ARB_vertex_array_bgra GL_ARB_vertex_array_object GL_ARB_vertex_buffer_object GL_ARB_vertex_program GL_ARB_vertex_shader GL_ARB_window_pos GL_ATI_draw_buffers GL_ATI_texture_float GL_ATI_texture_mirror_once GL_S3_s3tc GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_blend_color GL_EXT_blend_equation_separate GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_depth_bounds_test GL_EXT_direct_state_access GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit GL_EXT_framebuffer_multisample GL_EXT_framebuffer_object GL_EXT_gpu_program_parameters GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters GL_EXT_provoking_vertex GL_EXT_rescale_normal GL_EXT_secondary_color GL_EXT_separate_shader_objects GL_EXT_separate_specular_color GL_EXT_shadow_funcs GL_EXT_stencil_two_side GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_compression_dxt1 GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic GL_EXT_texture_format_BGRA8888 GL_EXT_texture_lod GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp GL_EXT_texture_object GL_EXT_texture_sRGB GL_EXT_texture_sRGB_decode GL_EXT_texture_storage GL_EXT_texture_swizzle GL_EXT_timer_query GL_EXT_vertex_array GL_EXT_vertex_array_bgra GL_EXT_x11_sync_object GL_EXT_import_sync_object GL_IBM_rasterpos_clip GL_IBM_texture_mirrored_repeat GL_KTX_buffer_region GL_NV_alpha_test GL_NV_blend_minmax GL_NV_blend_square GL_NV_complex_primitives GL_NV_copy_depth_to_color GL_NV_depth_clamp GL_NV_ES1_1_compatibility GL_NV_fbo_color_attachments GL_NV_fence GL_NV_float_buffer GL_NV_fog_distance GL_NV_fragdepth GL_NV_fragment_program GL_NV_fragment_program_option GL_NV_fragment_program2 GL_NV_framebuffer_multisample_coverage GL_NV_half_float GL_NV_light_max_exponent GL_NV_multisample_filter_hint GL_NV_occlusion_query GL_NV_packed_depth_stencil GL_NV_pixel_data_range GL_NV_point_sprite GL_NV_primitive_restart GL_NV_register_combiners GL_NV_register_combiners2 GL_NV_texgen_reflection GL_NV_texture_barrier GL_NV_texture_compression_vtc GL_NV_texture_env_combine4 GL_NV_texture_expand_normal GL_NV_texture_lod_clamp GL_NV_texture_rectangle GL_NV_texture_shader GL_NV_texture_shader2 GL_NV_texture_shader3 GL_NV_vertex_array_range GL_NV_vertex_array_range2 GL_NV_vertex_program GL_NV_vertex_program1_1 GL_NV_vertex_program2 GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_NVX_conditional_render GL_OES_compressed_paletted_texture GL_OES_depth24 GL_OES_depth32 GL_OES_depth_texture GL_OES_element_index_uint GL_OES_fbo_render_mipmap GL_OES_get_program_binary GL_OES_mapbuffer GL_OES_packed_depth_stencil GL_OES_point_size_array GL_OES_point_sprite GL_OES_rgb8_rgba8 GL_OES_read_format GL_OES_standard_derivatives GL_OES_texture_3D GL_OES_texture_float GL_OES_texture_float_linear GL_OES_texture_half_float GL_OES_texture_half_float_linear GL_OES_texture_npot GL_OES_vertex_array_object GL_OES_vertex_half_float GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture GL_SGIX_shadow GL_SUN_slice_accum
21:58:26.797 T:2980051776 NOTICE: Running database version Addons27
21:58:26.802 T:2980051776 NOTICE: Running database version ViewModes6
21:58:26.816 T:2980051776 NOTICE: Running database version Textures13
21:58:26.847 T:2980051776 NOTICE: Running database version MyMusic60
21:58:26.875 T:2980051776 NOTICE: Running database version MyVideos107
21:58:26.877 T:2980051776 NOTICE: Running database version TV29
21:58:26.912 T:2980051776 NOTICE: Running database version Epg11
21:58:26.939 T:3000190848 NOTICE: start dvd mediatype detection
21:58:28.088 T:3000190848 WARNING: JSONRPC: Could not parse type “Setting.Details.SettingList”
21:58:28.857 T:3000190848 NOTICE: initialize done
21:58:28.857 T:3000190848 NOTICE: Running the application…
21:58:28.976 T:3000190848 NOTICE: starting zeroconf publishing
21:58:28.977 T:3000190848 NOTICE: CWebServer[8080]: Started
21:58:28.977 T:3000190848 NOTICE: starting upnp client
21:58:29.013 T:2738879296 NOTICE: ES: Starting UDP Event server on port 9777
21:58:29.013 T:2738879296 NOTICE: UDP: Listening on port 9777 (ipv6 : false)
21:58:29.332 T:2980051776 ERROR: AddOnLog: PVR IPTV Simple Client: Unable to load playlist file ‘q’: file is missing or empty.
21:58:30.147 T:2980051776 NOTICE: Start - EPG thread started
21:58:40.475 T:2861538112 NOTICE: NEXTUP SERVICE NOTIFICATION Service → Starting NextUp Service
21:58:40.475 T:2861538112 NOTICE: NEXTUP SERVICE NOTIFICATION Service → ======== START NEXTUP SERVICE NOTIFICATION ========
21:58:40.475 T:2861538112 NOTICE: NEXTUP SERVICE NOTIFICATION Service → KODI Version: 17.1-RC1
21:58:40.475 T:2861538112 NOTICE: NEXTUP SERVICE NOTIFICATION Service → NEXTUP SERVICE NOTIFICATION Version: 1.0.35
21:58:40.475 T:2869926720 NOTICE: Skin Helper Service → skin helper service version 1.0.100 started
21:58:40.476 T:2869926720 NOTICE: Skin Helper Service → WebService - start helper webservice on port 52307
21:58:42.002 T:2886703936 WARNING: CSkinInfo: failed to load skin settings
