I just updated the system in my rpi2 using “My OSMC” -> “Scan for updates now”, and after completing the process and rebooting, it doesn’t get past the rainbow screen. No ssh either. Any clues?
Looks like I gave you some advice on using the staging repo in April. That’s an experimental repository.
If you didn’t switch back, you may have downloaded some updates that aren’t quite ready yet.
You can downgrade the kernel manually by moving the old vmlinuz and dtb directory in to place.
Great catch, Sam! I would have sworn I commented out that line, but turns out I didn’t.
Thank you very much,
David
