I have a rpi2 and so far nothing works for me, I was using a Sandisk card now I bought a Transcend 32Gb premium 400X and does not work, it gets stuck on the start screen the rainbow one, I did the tdoverlay on the config file and I use the last image 2015.1.11 but not sure if I have the correct image on the sd card, I am using a mac but i guess thats not the problem also i tried with Noobs and get the same situation always stuck on the rainbow,
how many files and what are the names of the files that i should have on the image, should I have a name on the card, my card is label no name
files in my card:
bootcode.bin
cmdline.txt
filesystem.tar.xy
fixup_cd.dat
kernel.img
preseed.cfg
start_cd.elf
config.txt - inside this one:
dtoverlay=mmc
disable_overscan=1
framebuffer_depth=32
gpu_mem=16
hope that some one can help me here
