Submenu icons
Hello. May I set submenu icons instead of plain text.
I want to have App (menu item) with Youtube icon (submenu item).
http://kodi.wiki/view/Skin_development_introduction
You should start here. I’ll tell you though, what you wish to do is not a simple configuration. Good luck.
Please help me. I don’t understand. How add icon in submenu?
The default skin does not support it. Either change your skin to a skin that does support it or you’ll need to re-engineer the skin yourself using the link that ActionA provided but it’s not straight forward.
I fix it. If you use osmc skin You should edit Home.xml file (in ssh terminal put “find / -name Home.xml”).
Evening I will add an example and embedding.
