Hello,
Currently i am watching an anime series with over 800 episodes on my vero 4k, accessing my PC HD on the mediaplayer and playing it. Up until episode 455 no problems, but now suddenly the episodes and video playback lacks in general. It seems for some reason the player cant keep up (the same happens when i try to play it from a portable hd via usb).
Yesterday i watched 455 no problem, and today when i start 456 this happens.
Im not sure about the replicate thing, but the player is still not playing these episodes well.
I have compared 455 and 456 on Media-info and they are exactly the same.
Not to sure about the new version, dont think i updated since yesterday. Though the vero is always on.
Never installed any add-ons whatsoever.
General
Unique ID : 212335428254911295711318275326243864346 (0x9FBE50E24C6EFC5B9BDB86B9A1A57F1A)
Complete name :
Format : Matroska
Format version : Version 2
File size : 285 MiB
Duration : 23 min 34 s
Overall bit rate : 1 690 kb/s
Encoded date : UTC 2010-06-22 23:37:56
Writing application : mkvmerge v4.0.0 (âThe Stars were mineâ) built on Jun 6 2010 16:18:42
Writing library : libebml v1.0.0 + libmatroska v1.0.0
Attachments : Impress BT.ttf / PRISTINA.TTF
Video
Format : AVC
Format profile : High@L4
Format settings : CABAC / 9 Ref Frames
Format settings, CABAC : Yes
Format settings, RefFrames : 9 frames
Codec ID : V_MPEG4/ISO/AVC
Width : 1 280 pixels
Height : 720 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 24.000 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Writing library : x264 core 98 r1649 c54c47d
Encoding settings : cabac=1 / ref=9 / deblock=1:0:0 / analyse=0x3:0x13 / me=umh / subme=9 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=24 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / constrained_intra=0 / bframes=9 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=3 / weightb=1 / weightp=2 / keyint=250 / keyint_min=25 / scenecut=40 / intra_refresh=0 / rc_lookahead=120 / rc=crf / mbtree=1 / crf=20.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:0.60
Language : English
Default : No
Forced : No
Color range : Limited
Matrix coefficients : BT.709
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : A_AAC-2
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Default : Yes
Forced : No
Text
Format : ASS
Codec ID : S_TEXT/ASS
Codec ID/Info : Advanced Sub Station Alpha
Compression mode : Lossless
Language : English
Default : Yes
Forced : No
Menu
00:00:00.000 : en:Opening
00:03:17.406 : en:Recap
00:03:29.459 : en:Part 1
00:13:39.552 : en:Part 2
00:23:04.592 : en:Preview
From the log:
23:05:39.364 T:4077953616 NOTICE: VideoPlayer: Opening: ftp://USERNAME:PASSWORD@192.168.2.3:21/Anime/One Piece/One Piece 451-500/451 - 474/One Piece 456.mkv
23:05:39.365 T:3079664384 NOTICE: Creating InputStream
23:05:39.593 T:3079664384 NOTICE: Creating Demuxer
23:05:39.674 T:3079664384 NOTICE: Opening stream: 0 source: 256
23:05:39.674 T:3079664384 NOTICE: Creating video codec with codec id: 28
23:05:39.675 T:3079664384 ERROR: Unable to load libamplayer.so, reason: libamplayer.so: cannot open shared object file: No such file or directory
23:05:39.675 T:3079664384 WARNING: CAMLCodec::CAMLCodec libamplayer.so not found, trying libamcodec.so instead
23:05:39.675 T:3079664384 ERROR: CVideoPlayerVideo::OpenStream - Invalid framerate 500, using forced 25fps and just trust timestamps
23:05:39.675 T:3079664384 NOTICE: Creating video thread
23:05:39.675 T:3079664384 NOTICE: Opening stream: 1 source: 256
23:05:39.675 T:3647636224 NOTICE: running thread: video_thread
23:05:39.675 T:3079664384 NOTICE: Finding audio codec for: 86018
23:05:39.677 T:3079664384 NOTICE: Creating audio thread
23:05:39.677 T:3096441600 NOTICE: running thread: CVideoPlayerAudio::Process()
23:05:39.677 T:3079664384 NOTICE: Opening stream: 2 source: 256
23:05:39.697 T:3096441600 NOTICE: Creating audio stream (codec id: 86018, channels: 2, sample rate: 48000, no pass-through)
23:05:39.702 T:3647636224 NOTICE: CAMLCodec::OpenDecoder - using V4L2 pts format: 64Bit
23:05:41.103 T:4077953616 NOTICE: Display resolution ADJUST : 1920x1080 @ 50.00 - Full Screen (26) (weight: 0.000)
23:05:41.103 T:4077953616 NOTICE: VideoPlayer: OnLostDisplay received
23:05:41.358 T:4077953616 NOTICE: VideoPlayer: OnResetDisplay received
23:05:57.099 T:4077953616 NOTICE: Display resolution ADJUST : 1920x1080 @ 23.98 - Full Screen (28) (weight: 0.000)
23:05:57.100 T:4077953616 NOTICE: VideoPlayer: OnLostDisplay received
23:05:57.445 T:4077953616 NOTICE: VideoPlayer: OnResetDisplay received
23:06:12.678 T:3647636224 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
23:07:12.321 T:4077953616 WARNING: Previous line repeats 1 times.
23:07:12.321 T:4077953616 NOTICE: VideoPlayer: OnLostDisplay received
23:07:12.568 T:4077953616 NOTICE: VideoPlayer: OnResetDisplay received
23:07:12.639 T:3647636224 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
23:07:18.363 T:4077953616 NOTICE: Display resolution ADJUST : 1920x1080 @ 23.98 - Full Screen (28) (weight: 0.000)
23:07:18.363 T:4077953616 NOTICE: VideoPlayer: OnLostDisplay received
23:07:18.693 T:4077953616 NOTICE: VideoPlayer: OnResetDisplay received
23:07:22.455 T:4077953616 NOTICE: VideoPlayer: OnLostDisplay received
23:07:22.755 T:4077953616 NOTICE: VideoPlayer: OnResetDisplay received
23:07:22.831 T:3647636224 WARNING: CRenderManager::WaitForBuffer - timeout waiting for buffer
23:07:31.605 T:4077953616 NOTICE: CVideoPlayer::CloseFile()
23:07:31.605 T:4077953616 NOTICE: VideoPlayer: waiting for threads to exit
23:07:31.614 T:3079664384 NOTICE: CVideoPlayer::OnExit()
23:07:31.614 T:3079664384 NOTICE: Closing stream player 1
23:07:31.614 T:3079664384 NOTICE: Waiting for audio thread to exit
23:07:31.632 T:3096441600 NOTICE: thread end: CVideoPlayerAudio::OnExit()
23:07:31.632 T:3079664384 NOTICE: Closing audio device
23:07:31.675 T:3079664384 NOTICE: Deleting audio codec
23:07:31.676 T:3079664384 NOTICE: Closing stream player 2
23:07:31.676 T:3079664384 NOTICE: waiting for video thread to exit
23:07:31.676 T:3647636224 ERROR: Got MSGQ_ABORT or MSGO_IS_ERROR return true
23:07:31.676 T:3647636224 NOTICE: thread end: video_thread
23:07:31.676 T:3079664384 NOTICE: deleting video codec
23:07:31.705 T:3079664384 NOTICE: Closing stream player 3
23:07:31.755 T:4077953616 NOTICE: VideoPlayer: finished waiting
23:07:31.759 T:4077953616 NOTICE: CVideoPlayer::CloseFile()
23:07:31.759 T:4077953616 NOTICE: VideoPlayer: waiting for threads to exit
23:07:31.759 T:4077953616 NOTICE: VideoPlayer: finished waiting
23:07:32.450 T:3351245568 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
23:07:45.774 T:3866448640 NOTICE: Previous line repeats 15 times.
23:07:45.774 T:3866448640 WARNING: CSkinInfo: failed to load skin settings
23:07:45.885 T:3866448640 ERROR: EXCEPTION: Non-Existent Control 300
23:07:46.430 T:3351245568 NOTICE: CDVDVideoCodecFFmpeg::Open() Using codec: H.264 / AVC / MPEG-4 AVC / MPEG-4 part 10
23:11:37.580 T:4077953616 NOTICE: Previous line repeats 5 times.
I hope you can help.
Kind Regards,
Harold
