SUPER FAVORITES UNINSTALL messed up right-click context menu
After uninstalling this there is no right-click context menu in the file manager and no error popup.
So I cant delete, rename, copy, etc.
Reboot doesn’t help
December’s new images don’t reset it
So it’s messed up something in my settings.
The quick workaround is to reinstall SUPER FAVORITES, and the regular menu appears at the bottom !
You should be reporting this to the developers of the Super Favorites addon in the addon subform of the Kodi forums.
