What are some of the currently supported chipsets for WiFi dongles? Do you have suggestions for ones that work well?
Most of the content I stream on my OSMC Raspberry Pi is SD and totally fine over WiFi. The problem is the built-in WiFi is abysmal. It currently works as long as I don’t use any other wireless devices in the area. If I do, the transfer speed drops to below 100kb/s. UGH. Any other device on the network can sustain multiple MB/sec simultaneously, so I need a better alternative.
Thanks!
