Honestly, the experience I’ve had with VERO and OSMC is the worst I’ve had with any kind of kodi set-up. After every update something new comes up. I know that this may happen with open systems, but it’s still annoying.
- Now for the x-th time the suspend mode does not work properly. It goes into suspend mode and sometimes I am not able to return from that. Then I have to pull the plug.
- Furthermore, the database seems to be somehow broken. Some movies are not displayed in the movies section nor are they displayed in videos -> files. However, I can find the movies via the search function. I am able to start the movies, but they have no sound.
My database is set up on a NAS and every device accesses it properly, except for Vero. It worked properly in that regard for months, but since we avoid using the Vero, I do not know, when this issue came up. It’s just present now.
